HELP my imported SWF
Jun 29, 2011 5:05 AM
I have created an animation of a superman like character flying with the animation being his cape flapping, his eye moving occasionally, and he moves up and down slightly to imitate the movement of flight.
I exported that animation as a SWF movie.
I then opened a new document and then imported that SWF file into the library to use, but when I place it on the stage, the functionality doesn't work. The only animation that has carried over from the original file is the cape flapping. The moving eye doesn't work, and he doesn't move up and down anymore.
I'm quite new to animation in flash, so maybe I'm exporting and importing too many times or something, or I'm just not going about it the right way.
Should multiple animations be done in the same document? or should they be done individually and then all imported into a new document where they all come together?
All help and advice most welcome.
Thank you.
    Jun 29, 2011 5:14 AM   in reply to le_mac_man
    While it can depend on how you made the animations, in general, it is not a good idea to "import" an SWF into an fla, mainly because any actionscript involved with the animation is dropped.  The correct way to bring content from one Flash file into another Flash file is to copy the timeline and paste it into the new file, either as the main timeline or as the timeline of a movieclip.
    Jun 29, 2011 7:38 AM   in reply to le_mac_man
    How are the animations done?  What process did you follow to copy the layers into your other file?
    Jun 29, 2011 8:23 AM   in reply to le_mac_man
    What I would recommend is that you work in just one file... do not import other swf files.  Build each animation as a movieclip within that one file.  Then place all the movieclips on the timeline together and they should all play while occupying only one frame of the main timeline.  You can divide them onto separate layers for easier access/referrence, but to avoid unnecessary complication, it is better that you learn to work within one file instead of building pieceparts as separate files.
    Jul 5, 2011 3:52 PM   in reply to le_mac_man
    To copy a timeline into another file or into a movieclip, first select all the frames you intend to copy.  Then right click the selection and choose Copy Frames.  Then go to the empty timeline of the MovieClip, select the keyframe in its only layer, right click the selected frame and choose Paste Frames.  The layers and frames that were copied will fill out as they were in the original timeline.
    Jul 7, 2011 9:10 AM   in reply to le_mac_man
    To create a new movieclip you select Insert -> New Symbol -> MovieClip
