ComboBox in a Spark DataGrid
Jul 5, 2011 7:46 AM
Hello,
Is there any difference between setting the data provider of a combo box in the MXML, and setting it from an actionscript code?
In the example below I create a table. The first column has combo editor with data provider set in the mxml. For the second I listen for a grid item editor session start event and then set the data provider. I expect that both columns should behave the same, but if I click on item from the second column, then it's not selected in the list and moreover is cleared when I click another cell. Could you please help? What could be the problem?
<s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                            xmlns:mx="library://ns.adobe.com/flex/mx"
                            creationComplete="creationCompleteHandler(event)">
     <fx:Script>
          <![CDATA[
               import mx.controls.ComboBox;
               import mx.events.FlexEvent;
               import spark.components.gridClasses.ComboBoxGridItemEditor;
               import spark.events.GridItemEditorEvent;
               protected function creationCompleteHandler(event:FlexEvent):void
                    grid.dataProvider = new ArrayList([
                         {column1:'red',column2:'red',column3:'red'},
                         {column1:'red',column2:'red',column3:'red'}]);
                    grid.addEventListener(GridItemEditorEvent.GRID_ITEM_EDITOR_SESSION_START, prepareCellEditor);
               protected function prepareCellEditor(event:GridItemEditorEvent):void
                    if (event.column.dataField == 'column2') {
                         var comboEditor : ComboBoxGridItemEditor = event.currentTarget.itemEditorInstance as ComboBoxGridItemEditor;
                         comboEditor.dataProvider = new ArrayList(['red','green','blue']);
     </fx:Script>
     <s:DataGrid id="grid" editable="true" width="100%" height="100%">
          <s:columns>
               <s:ArrayList>
                    <s:GridColumn dataField="column1" headerText="Column 1">
                         <s:itemEditor>
                              <fx:Component>
                                   <s:ComboBoxGridItemEditor>
                                        <s:dataProvider>
                                             <s:ArrayList>
                                                  <fx:String>red</fx:String>
                                                  <fx:String>green</fx:String>
                                                  <fx:String>blue</fx:String>
                                             </s:ArrayList>
                                        </s:dataProvider>
                                   </s:ComboBoxGridItemEditor>
                              </fx:Component>
                         </s:itemEditor>
                    </s:GridColumn>
                    <s:GridColumn dataField="column2" headerText="Column 2" itemEditor="spark.components.gridClasses.ComboBoxGridItemEditor"/>
                    <s:GridColumn dataField="column3" headerText="Column 3"/>
               </s:ArrayList>
          </s:columns>
     </s:DataGrid>
</s:WindowedApplication>
Thanks in Advance!
Regards,
Dinko
    Apr 3, 2013 6:40 AM   in reply to dinko_ivanov
    to set the dataProvider of the ComboBoxGridItemEditor dynamically in ActionScript
    I use this:
    [code]
    var dataList:ArrayList = new ArrayList(["one", "two", "three"]);
    var cF:ClassFactory = new ClassFactory(ComboBoxGridItemEditor);
    cF.properties = {dataProvider: dataList};
    yourEditableColumn.itemEditor = cF;
    [/code]
