xophiix
Compile Error in com.adobe.pixelBender3D.translator.transformations::RegisterAssigner/ renameAndAdjus
Jul 6, 2011 7:09 PM
I removed all custom function in my shader and removed the confusing "Incorrect function" error.
But still got this error in AS code, really frustrating!!! the vertex shader code looks fine! fragment shader just do a simple texture sampling to make sure it's ok. I can't see anything wrong in my code. Please help!  I'm sure of that pb3dutil compile ok and I clean and rebuild my project to make sure the embeds.
Error in as code:
// occured at this line: PBASMCompiler.compile
var programs : com.adobe.pixelBender3D.AGALProgramPair = com.adobe.pixelBender3D.PBASMCompiler.compile( inputVertexProgram, inputMaterialVertexProgram, inputFragmentProgram );
TypeError: Error #1009: Cannot access a property or method of a null object reference.
     at com.adobe.pixelBender3D.translator.transformations::RegisterAssigner/ renameAndAdjustSourceRegister()[D:\src\aif\sdk\main\pixel_bender_3d\pb 3dlib\src\com\adobe\pixelBender3D\translator\transformations\RegisterA ssigner.as:418]
     at Function/<anonymous>()[D:\src\aif\sdk\main\pixel_bender_3d\pb3dlib\sr c\com\adobe\pixelBender3D\translator\transformations\RegisterAssigner. as:352]
     at Vector.<*>$/_forEach()
     at Vector$object/http://adobe.com/AS3/2006/builtin::forEach()
     at Function/<anonymous>()[D:\src\aif\sdk\main\pixel_bender_3d\pb3dlib\sr c\com\adobe\pixelBender3D\translator\transformations\RegisterAssigner. as:380]
     at com.adobe.pixelBender3D.translator.transformations::RegisterAssigner/ renameAndAdjust()[D:\src\aif\sdk\main\pixel_bender_3d\pb3dlib\src\com\ adobe\pixelBender3D\translator\transformations\RegisterAssigner.as:387 ]
     at com.adobe.pixelBender3D.translator.transformations::RegisterAssigner/ assignRegisters()[D:\src\aif\sdk\main\pixel_bender_3d\pb3dlib\src\com\ adobe\pixelBender3D\translator\transformations\RegisterAssigner.as:120 ]
     at com.adobe.pixelBender3D.translator.transformations::RegisterAssigner( )[D:\src\aif\sdk\main\pixel_bender_3d\pb3dlib\src\com\adobe\pixelBende r3D\translator\transformations\RegisterAssigner.as:66]
     at Translator/http://ns.adobe.com/pb3d/internal/2010::translate()[D:\src\aif\sdk\main\pixel_bender_3d\pb3dlib\src\com\adobe\pixelBend er3D\translator\Translator.as:1882]
     at com.adobe.pixelBender3D.translator::VertexTranslator/http://ns.adobe.com/pb3d/internal/2010::translate()[D:\src\aif\sdk\main\pixel_bender_3d\pb3dlib\src\com\adobe\pixelBend er3D\translator\VertexTranslator.as:143]
     at com.adobe.pixelBender3D::Translator$/translate()[D:\src\aif\sdk\main\ pixel_bender_3d\pb3dlib\src\com\adobe\pixelBender3D\Translator.as:69]
     at com.adobe.pixelBender3D::PBASMCompiler$/compile()[D:\src\aif\sdk\main \pixel_bender_3d\pb3dlib\src\com\adobe\pixelBender3D\PBASMCompiler.as: 57]
     at deltax.graphic.render::SkinnedMeshPass/updateProgram()[E:\Flash\proje ct_w11a\branch\develop_version\as\deltax\src\deltax\graphic\render\Ski nnedMeshPass.as:113]
and the vertex code:
<languageVersion : 1.0;>
vertex kernel SkinnedMesh
    namespace : "AIF Test";
    vendor : "Adobe";
    version : 1;
     parameter float4x4 worldViewProjectionMatrix;
     const int MAX_BONE_TRANSFORM = 39 * 3;
     // no 4x3 matrix so...
     parameter float4 boneTransforms[ MAX_BONE_TRANSFORM ];
    input vertex float3 vertexPosition
     input vertex float3 vertexNormal
    input vertex float4 boneIndice
    input vertex float4 boneWeights
    output float4 vertexClipPosition;
    void evaluateVertex()
          float4 inPos4 = float4( vertexPosition.x, vertexPosition.y, vertexPosition.z, 1.0 );
          int4 indice = int4( boneIndice );
          float4 result = float4(0.0);
          result.x = dot( inPos4, boneTransforms[indice.x] );
          result.y = dot( inPos4, boneTransforms[indice.x + 1] );
          result.z = dot( inPos4, boneTransforms[indice.x + 2] );
          result = result * boneWeights.x;
          result.x += dot( inPos4, boneTransforms[indice.y] ) * boneWeights.y;
          result.y += dot( inPos4, boneTransforms[indice.y + 1] ) * boneWeights.y;
          result.z += dot( inPos4, boneTransforms[indice.y + 2] ) * boneWeights.y;
          result.x += dot( inPos4, boneTransforms[indice.z] ) * boneWeights.z;
          result.y += dot( inPos4, boneTransforms[indice.z + 1] ) * boneWeights.z;
          result.z += dot( inPos4, boneTransforms[indice.z + 2] ) * boneWeights.z;
          result.x += dot( inPos4, boneTransforms[indice.w] ) * boneWeights.w;
          result.y += dot( inPos4, boneTransforms[indice.w + 1] ) * boneWeights.w;
          result.z += dot( inPos4, boneTransforms[indice.w + 2] ) * boneWeights.w;
          result.w = 1.0;
        vertexClipPosition = result * worldViewProjectionMatrix;
    Jul 11, 2011 5:55 PM   in reply to xophiix
    I don't see anything obviously wrong - we'll look into it. It is possible that the kernel is simply too big (in which case we should be giving you a much more meaningful error). Our instruction limit is very low.
    Bob
    Sep 26, 2011 11:54 AM   in reply to AIF Bob
    This problem has been fixed in preview 3 of Pixel Bender 3D
    Bob
