AME CS5.5 hangs on "Reading XMP"
Jul 7, 2011 8:38 AM
  Latest reply: h2ofun, Mar 13, 2013 5:21 PM
    May 8, 2012 7:29 PM   in reply to DaveTrayers
    Sorry about your drive but it's great that you still have the source footage.
    Having the whole project would be ideal. I will message you the FTP server info tomorrow.
    We really appreciate your help with this.
    May 22, 2012 1:54 PM   in reply to Dima Tikhonov
    I am getting the same issues  I tried the method to delete C:\Users\{user}\AppData\Roaming\Adobe\Adobe Media Encoder\5.5
    and it still doesn't fix it. i
    I'm on a PC, Windows 7, 64bit, i7 Processor, 16gb ram, and I've never had issues before.
    I just logged up a bunch of clips and went to bed, when I woke up it was stuck "reading XMP" with no hopes of getting out of it. I then skipped the file and then the next file is giving me the same endless "processing: Reading XMP" status. Except now it's frozen.
    I've restarted my computer and reloaded the que - still frozen.
    When I did the delete APPDATA method, PP couldn't export to AME anymore! HELP!
    May 22, 2012 4:23 PM   in reply to trajoj
    Try unchecking the "Write XMP ID to files"  in the Preferences -> General for AME, and also in PPr uncheck "Write XMP ID" and "Enable Clip and XMP Metadata Linking" in Preferencecs -> Media.
    It worked for me.
    May 22, 2012 7:56 PM   in reply to DaveTrayers
    I've got it working like it was last night (it had a small que of about 5 videos). I'm scared to load it up and go to bed in fear I'll lose everything and have to re-export each clip (1 at a time). I'll have to try it though since I have a ton of stuff to export tonight!
    May 23, 2012 6:38 PM   in reply to trajoj
    Last night I changed those XMP settings to what you suggested and it seemed to be working fine, but then I woke up this morning, same error!
    This time I close and restart it, rename that folder, restart my computer, and it still won't export!
    Oct 6, 2012 7:01 AM   in reply to trajoj
    I think I solved the problem... At least on my own computer
    When I chose not to render the audio, it worked  perfectly.. No hanging on the XML-thing.
    I had a project with  audio from the cam (48KHz) and audio from an external recorder (44.1). The project was 48....I only used the 44.1 file in the project, by the way. Because I used multicam, there was no easy way, to convert the project, so I dragged the audiofile(s) into AME and rendered it out as 48KHz and replaced it in premiere. And it worked!
    Hopefully I will think about the different recording formats in the future and hope my problem is solved for good!
    Oct 12, 2012 1:23 AM   in reply to Pmygind
    Same for me. None of the other suggestions worked, but turning off audio solved it.
    Oct 22, 2012 4:28 PM   in reply to hsredna
    I solved it, with Pmygind comment, would be great if premiere show a advice about this problem/incompatibility with the sample rate
    I was using CS6 suite (Premiere 6.0.3).
    Mar 13, 2013 5:21 PM   in reply to Pmygind
    So, how are you folks chosing to not render the audio?  I just started having the same issue.
Bookmarked By (1)
