Dynamically change text during narration
Jul 11, 2011 8:06 AM
Hi!
I've got a file that contains narration. The content appears progressively on the stage as narration plays.
On the first frame I added a dynamic textfield, which I called : soustitrage_txt (would be "caption_txt" in English).
On another layer, on the same frame I added this code :
soustitrage_txt.html = true;
soustitrage_txt.autoSize = "left";
soustitrage_txt.selectable = true;
soustitrage_txt.multiline = true;
soustitrage_txt.wordWrap = true;
var txtFormat:TextFormat = new TextFormat();
txtFormat.size = 20;
txtFormat.font = "Arial";
txtFormat.bold= true;
//I exagerated the value, to be sure it's really not working...
_global.myData = new LoadVars();
_global.myData.load("p1.txt");
_global.myData.onLoad = function() {
      soustitrage_txt.setTextFormat(txtFormat);
I need to make appear the first sentence around the frame 115, in which I entered this code on my "action layer" :
soustitrage_txt.text = _global.myData.phrase1;
One positive point, the text appears (yay!) but the negative point is that the formatting doesn't work...
Finally, when I want to switch to the next phrase, around frame 195, I enter the same code (with only a different variable name to call) :
soustitrage_txt.text = _global.myData.phrase2;
And now it shows me "undefined"... :/
Here's a preview of my external text file (I translated it...since it's in French normally) :
phrase1=Hello and welcome to this guide that will show you how to adjust your workstation step by step.&
phrase2=Adjusting your workstation properly will prevent you from having any discomfort that may result from bad posture or improper adjustment.&
phrase3=...&
(and so on...)
Thanks a lot!
Geneviève
    Jul 11, 2011 8:27 AM   in reply to jacquesge
    If you are placing those ampersands at the end followed by a carriage return as you seem to be per what you posted, don't do that. Keep them adjacent to variables they are defining.
    &phrase2=Adjusting your workstation properly will prevent you from having any discomfort that may result from bad posture or improper adjustment.
    &phrase3=...
    Jul 11, 2011 8:58 AM   in reply to jacquesge
    You need to set the textformat after you assign the text, not before.
