Problem installing Adobe eLearning on MS Windows 7 64-bit
Jul 12, 2011 8:46 AM
I am trying to install Adobe eLearning on MS Windows 7 64-bit. Any ideas why my installation is failing? The log is below:
P.S. I donwloaded it twice to ensure that the installation binaries are correct.
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 97 error(s), 93 warning(s)
----------- Payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0 -----------
ERROR: Error 1935.An error occurred during the installation of assembly component {43CC1B37-B20C-3EBC-9C04-F809989E4FD3}. HRESULT: 0x80070003.
ERROR: Install MSI payload failed with error: 1603 - Fatal error during installation.
MSI Error message: Error 1935.An error occurred during the installation of assembly component {43CC1B37-B20C-3EBC-9C04-F809989E4FD3}. HRESULT: 0x80070003.
WARNING: DW036: Payload cannot be installed due to dependent operation failure
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe ExtendScript Toolkit CS5.5: Install failed
ERROR: DW050: - Adobe Dreamweaver CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - Microsoft_VC90_ATL_x86: Install failed
ERROR: DW050: - Adobe Linguistics CS5 x64: Install failed
ERROR: DW050: - Microsoft_VC90_CRT_x86: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 Core: Failed due to Language Pack installation failure
ERROR: DW050: - Microsoft_VC80_ATL_x86: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 Core_x64: Failed due to Language Pack installation failure
ERROR: DW050: - Recommended Common Fonts Installation x64: Install failed
ERROR: DW050: - Suite Shared Configuration CS5.5: Install failed
ERROR: DW050: - AdobePDFL x64 CS5: Install failed
ERROR: DW050: - DynamiclinkSupport: Install failed
ERROR: DW050: - Microsoft_VC80_MFCLOC_x86_x64: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 International English Language Pack_AdobePhotoshop12-en_GB: Install failed
ERROR: DW050: - Adobe Presenter 7 Installer Files for eLS 2.5: Install failed
ERROR: DW050: - Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-en_US: Install failed
ERROR: DW050: - Adobe XMP Panels CS5: Install failed
ERROR: DW050: - Pixel Bender Toolkit: Install failed
ERROR: DW050: - Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64: Install failed
ERROR: DW050: - Adobe Dreamweaver CS5.5_AdobeDreamweaver11.5en_USLanguagePack: Install failed
ERROR: DW050: - Photoshop Camera Raw: Install failed
ERROR: DW050: - Camera Profiles Installer: Install failed
ERROR: DW050: - Adobe Extension Manager CS5.5: Install failed
ERROR: DW050: - Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll: Install failed
ERROR: DW050: - Adobe Flash Player 10 Plugin: Install failed
ERROR: DW050: - AdobeColorCommonSetRGB: Install failed
ERROR: DW050: - Microsoft_VC80_CRT_x86_x64: Install failed
ERROR: DW050: - AdobeColorPhotoshop CS5.5: Install failed
ERROR: DW050: - AdobeCourseBuilder 6.5: Install failed
ERROR: DW050: - Adobe Device Central CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Mini Bridge CS5.1: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64: Install failed
ERROR: DW050: - AdobeColorCommonSetCMYK: Install failed
ERROR: DW050: - Adobe Captivate Reviewer: Install failed
ERROR: DW050: - Adobe Captivate Quiz Results Analyzer: Install failed
ERROR: DW050: - Photoshop Camera Raw (64 bit): Install failed
ERROR: DW050: - Microsoft_VC90_MFC_x86: Install failed
ERROR: DW050: - Adobe Media Encoder CS5.5 X64: Install failed
ERROR: DW050: - AIR for APPLE IOS Support (FP): Install failed
ERROR: DW050: - Adobe Linguistics CS5: Install failed
ERROR: DW050: - PDF Settings CS5: Install failed
ERROR: DW050: - AdobeTypeSupport CS5: Install failed
ERROR: DW050: - Adobe CSXS Infrastructure CS5.5: Install failed
ERROR: DW050: - Adobe Flash Player 10 ActiveX: Install failed
ERROR: DW050: - AdobeColorEU CS5.5: Install failed
ERROR: DW050: - Adobe Captivate 5.5: Failed due to Language Pack installation failure
ERROR: DW050: - AdobeHelp: Install failed
ERROR: DW050: - Required Common Fonts Installation x64: Install failed
ERROR: DW050: - Microsoft_VC90_ATL_x86_x64: Install failed
ERROR: DW050: - AdobeLearningInteraction 2.5: Install failed
ERROR: DW050: - Microsoft_VC90_MFCLOC_x86_x64: Install failed
ERROR: DW050: - Adobe Captivate 5.5_AdobeCaptivate5.5en_GBLanguagePack: Install failed
ERROR: DW050: - Microsoft_VC80_ATL_x86_x64: Install failed
ERROR: DW050: - Microsoft_VC90_CRT_x86_x64: Install failed
ERROR: DW050: - Microsoft_VC80_CRT_x86: Install failed
ERROR: DW050: - Adobe Device Central CS5.5_DeviceCentral3.5LP-en_GB: Install failed
ERROR: DW050: - MultiSCOPackager: Install failed
ERROR: DW050: - Adobe Flash CS5.5_AdobeFlash11.5-en_USLanguagePack: Install failed
ERROR: DW050: - AdobeCMaps x64 CS5: Install failed
ERROR: DW050: - AdobeTypeSupport x64 CS5: Install failed
ERROR: DW050: - Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All: Install failed
ERROR: DW050: - Microsoft_VC90_MFC_x86_x64: Install failed
ERROR: DW050: - AdobeColorJA CS5.5: Install failed
ERROR: DW050: - AdobeOutputModule: Install failed
ERROR: DW050: - Acrobat Professional: Install failed
ERROR: DW050: - Adobe Audition_AdobeAudition4en_USLanguagePack: Install failed
ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS5: Install failed
ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
ERROR: DW050: - Microsoft_VC90_MFCLOC_x86: Install failed
ERROR: DW050: - AdobePDFL CS5: Install failed
ERROR: DW050: - AdobeCMaps CS5: Install failed
ERROR: DW050: - Adobe CSXS Extensions CS5.5: Install failed
ERROR: DW050: - Microsoft_VC80_MFC_x86_x64: Install failed
ERROR: DW050: - Adobe ReviewPanel CS5.5: Install failed
ERROR: DW050: - Required Common Fonts Installation: Install failed
ERROR: DW050: - Adobe Player for Embedding x64 3.1: Install failed
ERROR: DW050: - Adobe SwitchBoard 2.0: Install failed
ERROR: DW050: - HIL Help Search: Install failed
ERROR: DW050: - Microsoft_VC80_MFC_x86: Install failed
ERROR: DW050: - Adobe Player for Embedding 3.1: Install failed
ERROR: DW050: - Adobe Audition: Failed due to Language Pack installation failure
ERROR: DW050: - Microsoft_VC80_MFCLOC_x86: Install failed
ERROR: DW050: - Adobe Flash CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - SiteCatalyst NetAverages CS5.5: Install failed
ERROR: DW050: - Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-mul: Install failed
ERROR: DW050: - Recommended Common Fonts Installation: Install failed
ERROR: DW050: - AdobeColorNA CS5.5: Install failed
ERROR: DW050: - AdobeJRE: Install failed
ERROR: DW050: - AdobeColorVideoProfilesCS CS5.5: Install failed
ERROR: DW050: - Adobe Bridge CS5.1: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 Support: Install failed
ERROR: DW050: - Adobe Dreamweaver Widget Browser: Install failed
ERROR: DW050: - Adobe eLearning Suite 2.5: Install failed
ERROR: DW050: - Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All: Install failed
