Is it possible to make a raster art object with the AIRasterizeSuite that takes into account the overprint preview ?
Today it is possible with Rasterize command of Illustrator(Object->Rasterize) but it converts our selection in a raster object. When the export is done, we need to undo the command to get back our objects. We need to export our document with the overprint preview several times so the cycle Rasterize<=> Undo becomes tedious.
Ok. Well, yes, you can definitely do that. Though the method will still create raster objects, at least it won't force you to hit undo
When you use the AIRasterize suite you get a kRasterArt object but it leaves the source alone. You can just delete the raster when you're done, after you've looted it for its gooey pixel goodness.
There's also the AIImageOptimization suite, which actually (I think) sends a rasterization of art directly to a file. When you use the AIRasterize suite, you'll have to to either figure out how to get AI to export the raster, or get its contents, interpret them and write them out in whatever format you want. That's obviously the more flexible way, but its a lot of work. If you can get the AIImageOptimationSuite to do what you need I'd try that. I haven't used it though, so I don't have much to offer in the way of advice on it -- perhaps someone else who has can help?
North America
Asia Pacific
