third monitor on NVIDIA 6600
Jul 13, 2011 2:18 AM
I recently changed computers and installed W7 64bts.
Also I upgraded PPRO, Encore and Audition to 5.5.
On my earlier system I did use the Matrox RTX 100 card to support the 3th monitor using the break out box s-video, which, I think,  will not working anymore on the W7 64 bts machine. So I quitte this card.
I think of following the suggestion given on this forum to install my old NVIDIA 6600 card, together with the new ENGTX570 NVIDIA card. The old card to suppport the 3th monitor.
I am not shure if this will work, neither if maybe the new card, which have two DVI, 1 HDMI and 1 DisplayPort will support the 3 monitors by itself using the two DVI for the 2 basic monitors and the DisplayPort for the 3th monitor.
Anyone have some expierience with this configuration? How do I configure PPRO 5.5 to drive the third monitor if this will work?
Thanks for replying.
Chris
    Jul 13, 2011 2:30 AM   in reply to Chris Nierop
    Chris,
    Despite all the connectors on you video card, all nVidia cards only allow 2 to be active at the same time. If you need more than 2 monitors at the same time, you can either use an AMD/ATI Eyefinity card or use two nVidia cards. The latter solution can be tricky, but since both of your suggested nVidia cards do NOT support hardware acceleration, you may be better off with a single AMD/ATI card. The alternative is to get two GTX 460+ cards and possibly a new PSU and more cooling. A third monitor is also possible with a firewire connection thru a camera/deck but only in SD and always without hardware acceleration.
    Jul 13, 2011 3:56 AM   in reply to Chris Nierop
    Chris,
    I misread your mention of the GTX 570 and read it instead as a Quadro FX 570, hence my remarks. Sorry.
    I would try to get a GTX 560 or even a GTX 550 as a second card, provided you can return it if it does not work as expected. They are the same generation as your current 570 and use the same drivers. Be sure that you activate the 570 as your CUDA card and use the other one only to connect your third or fourth monitor.
