Check box rendering problem in List.
Jul 13, 2011 2:39 AM
Hi All,
            I am using list component in my app and list component allows multiple selections. I am using an itemrenderer having the checkbox and label in hbox.
Rendering is working fine. but when I selected three or four items randomly using check boxes in list and If I scroll it vertically (up and down) the selections of check boxes changedto another items. If I keep on doing this finally I will get all the check boxes selected. but I have selected only three check boxes.
             I wanted get out of this problem. If i selected two or three checkboxes and when scroll it vertically it should remain as it is. Selections should not change... please help on this..
                 I am posting the code of Item renderer
<mx:HBox xmlns:mx="http://www.adobe.com/2006/mxml" horizontalGap="2"
    width="100%" height="100%"
    implements="mx.controls.listClasses.IDropInListItemRenderer"
    initialize="init()"
    verticalScrollPolicy="off"
    horizontalScrollPolicy="off"
    click="handleClick(event)">
    <mx:Metadata>
        [Event(name="checkBoxEvent", type="com.comp.name.ui.events.CheckBoxEvent")]
    </mx:Metadata>
    <mx:Script>
        <![CDATA[
            import mx.controls.List;
            import mx.controls.listClasses.ListData;
            import com.comp.name.ui.events.CheckBoxEvent;
            import com.comp.name.ui.filters.StringUtils;
            import mx.controls.dataGridClasses.DataGridListData;
            import mx.controls.listClasses.BaseListData;
            private var _listData:BaseListData;
            private var _list:List;
            public function init():void
                this.addEventListener(Event.CHANGE, onChangeEvent);
            public function get listData() : BaseListData
                return _listData;
            public function set listData( value:BaseListData ) : void
                _listData = value;
                if(listData)
                    _list = listData.owner as List
            override public function set data(value:Object):void
                super.data = value;
            protected function handleClick(event:MouseEvent):void
                if(check.selected)
                    check.selected = false;
                else
                    check.selected = true;
            protected function checkBoxSelected(event:Event):void
                if(data)
                    if(check.selected){
                        dispatchEvent(new CheckBoxEvent(CheckBoxEvent.CHECKBOX_EVENT, data.mx_internal_uid,data as Object, true,true));
                    }else
                        dispatchEvent(new CheckBoxEvent(CheckBoxEvent.CHECKBOX_EVENT, data.mx_internal_uid,data as Object, false,true));
            protected function onChangeEvent(event:Event):void
    </mx:Script>
    <mx:CheckBox id="check" change="checkBoxSelected(event)" click="handleClick(event)"/>
    <mx:Label id="lb" width="100%" height="100%" htmlText="{_list.labelFunction(data)}"/>
</mx:HBox>
I have faced this problem in so many times in so many list component..  Please help me on this...
    Jul 13, 2011 8:48 AM   in reply to flex4
    The selected state of the checkbox must be tied to some aspect of the data
    item.  See the posts on my blog about item renderers.
