Alex DeJesus 496 posts
Jul 25, 2008
Overclock Question ASUS Board Sandy Bridge
Jul 13, 2011 9:10 AM
The BIOS utility for the P8P67 Pro B3 Board has an EZ Mode that allows you to select from 3 performance presets: Powersaving, Normal, and Overclock mode. When I set it to Overclock, the system becomes unstable - won't bootup or will freeze during some operation.
There is also a tool for overclocking from within Windows after bootup. Again, anything other than the stock setting causes instability.
I had hoped to overclock the traditional manual way, but don't think it's a good idea if the presets don't work. I was wondering if anyone else had similar problems or should I disregard the presets.
CPU i7-2600k
16 GB RAM
    Jul 13, 2011 9:25 AM   in reply to Alex DeJesus
    installing any of those utilities on the mobo disk is a bad idea for that matter anything on the disk (all drivers should be downloaded other than the NIC so you can get on the internet)
    OCing needs to be done in the bios not thru software
    Scott
    ADK
    Jul 13, 2011 2:52 PM   in reply to Alex DeJesus
    I did read a big piece about easy -step by step- 2600k overclocking but i'm dutch and will spare you my funny language.
    But  it's very easy in general and a lot off the new 1155 motherboards like Asus also does have a very nice OC app included for clocking to +/- 5 GHz.
    Jul 13, 2011 3:00 PM   in reply to Alex DeJesus
    If you cannot overclock with those easy preset tools I suspect that your CPU may be overheating. What temperature are your cores running without overclocking?
    Jul 13, 2011 4:52 PM   in reply to Alex DeJesus
    Actually, in my case, the auto-overclock setting not only set the multiplier to 43x, but also raised the BCLK from its stock 100MHz to 103MHz, resulting in an overall clock speed of 4.429GHz. However, some i7-2600K CPUs start running unstably at this slightly elevated BCLK setting.
    Jul 13, 2011 5:46 PM   in reply to Alex DeJesus
    Here's the Asus ''easy to OC'' board
    http://www.asus.com/Motherboards/Intel_Socket_1155/P8H67M_PRO/
    My Q6600 is with org. cooler and no OC 65 degrees celcius, with 30 % OC and zalman cnps 7500 cpu cooler below 60 degrees celsius.
    Jul 13, 2011 7:08 PM   in reply to Alex DeJesus
    Actually, I was referring to the 103MHz BCLK, not the 4.429GHz core clock, as being "slightly elevated".
