Missing audio when exporting
Jul 15, 2011 4:01 PM
Hey All,
I've run into an error I've had before and hoping to fix it rather than by pass it.  I'm trying to export a video that has someone speaking to the camera (track 2) and a sound track (track 3) underneath them.  The voice is mono ... the sound track stereo.  When I watch the video in the preview monitor within Premiere both audio tracks are played.  When I export it - either as an avi or as a wave - the voice doesn't show up.  And because it will inevitably be the first question asked - no the voice track is not muted, and yes I have double checked.
In the past when I ran into this issue I believe I ran it through After Effects to get the audio ... but I'm hoping not to have to run around this time ... I'm hoping Premiere will work the way it is meant to.
And help would be greatly appreciated.
Kevin
    Jul 15, 2011 4:15 PM   in reply to Kevin Schuster
    Kevin,
    Just to make sure that things are, as I think they are, when you play your Timeline you not only hear the Audio from both Tracks perfectly, but also the Levels Meters reflect good Levels. Is that correct? For a test of the Levels, I'd watch in the Audio Mixer. Also, keep an eye on the sliders for that Voice Track. It should not move.
    Now, as you can hear both Tracks fine, there should not be an issue with Muting, or with Tracks being Enabled. If the Levels are good to your ears, and with the Meters, good to your eye, the only thing that I can think of would be Track Mapping. Has that been used? If so, where are the Tracks being Mapped to?
    As another test, Duplicate the Voice Clip(s), and Copy them to another mono Track. I would probably use Balance to bias one a bit left, and one a bit right. Listen, and then do a test Export to check.
    Just grasping at straws here, as I have no clear idea what could cause the problm that you describe.
    BTW - what is on Audio Track 1 - just curious.
    Jul 16, 2011 9:20 AM   in reply to Kevin Schuster
    Kevin,
    Here I come, with more "straws" in my hand...
    As a test, let's go back to that eariler Sequence, and try an Export of just the Audio, to a PCM/WAV @ 48KHz, 16-bit. Then, Import that WAV into your new Project and use it in your Sequence instead. Test.
    I still cannot come up with a good reason why you are getting the desired Audio w/ proper Levels in PrPro, but then it's missing in the Export. I think that we've ruled out about everything, such as Enable, Mute, Track Keyframes on Volume, etc., but there could be just one little setting, that is being overlooked. So many things that affect Audio, but those are usually heard in PrPro, prior to Export.
