Hi All...
I would like to receive an event(Dispatchd in Parent swf) in Child SWF, the bold italic text represents the piece of coding i require help with
//in PARENT SWF i have -----------------------------
dispatchEvent(new Event("CloseDoors"))
// in Child SWF --------------------------------
here i need a code that catches the event dispatched in parent.addEventListener("closeDoors",closedoor)
Please let me know if there are alternative ways to do it. I think some people prefer to listen to the event also in Parent file and run
the function in CHild from parent file....i would like to learn the best practive to INFORM CHILDREN through a PARENT FILE...
Thanks.
This is not a very good idea to make child listen to events from parent for it is not manageable very well. If there is dependency of child on parent - it is better to create a method in child and call this method from parent on child's instance.
Of course you can do that in the child:
parent.addEventListener("BLAH", handler); but, again, it is not a good approach. methods API is better (and faster). Events are the best when asynchronous/unpredictable things happen. When you know when things happen - calling methods is more appropriate.
Thanks....
Could you pls show me in a brief code what does it look like to create a method, i am also searching web regarding API to find out more by myself, I will appreciate an example...a brief code showing examples of Lines i have to write in PARENT file and CHILD....thanks.
Method is a function. I assume you know how to write functions in AS3...
Perfect....just to make sure i m taking care of it in a nice practical way....here is how i learned to access a file located in Child (researching other posts)
is this the way you recommend it?
(LoaderName.content as MovieClip).functionName(new Event("whatever"))
and in Child File we have
function functionName(e:Event)
i have seen other ways of calling a function in Child Swf , like using EmbedSWF and etc. wanna make sure which one is a better practice. Thanks
