Misha Ko
Console errors (multiple, 60-some) -- "value of separation out of range"
Jul 18, 2011 8:11 AM
I have a long, 128 page chapter.
I was getting a "font not found, substitute Times New Roman for MS Shell Dlg 2" console message when I
opened the file.
An online search turned up the suggestion that if you can't actually find the font in your doc, to get rid of it, saving the file as MIF, and opening
and re-saving to FM, might solve the problem. ("If the font isn't really there to begin with.")
It didn't work. The console error message from opening the MIF file says, **The "MS Shell Dlg 2" Font is not available. "Times New Roman"
will be used in this session.**
On top of which, that same console error window also has about 60 lines with a different numerical variation of:
MIF: "K:\Technical Publications Current Projects\00 yadda yadda filename.mif" (126817): Value of Separation out of range (11).
The messages are all the same, only the six digit numbers in parantheses change.
I'm on a (relatively) NEW Dell Precision T1500 box with 64 bit Win 7 & FM 9.0p255. All graphics in the file were imported by reference into
anchored frames from a "graphics n pix" folder in the same directory as the FM file.
....I don't know if this is really a problem or not, but the filie does take a heck of a long time to open, and there's
usually a paranthetical note in the window top bar, following the FM file name, that says Windows (not responding.)
Which goes away when the file does open. (In 2 or 3 minutes? Haven't put a stopwatch on it....)
This file is just one of many similarly sized docs, so I'm a little worried about what might happen when they're all collected
into the book file.
Any suggestions, info or advice would be much appreciated.
    Jul 18, 2011 8:24 AM   in reply to Misha Ko
    If the font name isn't found in the MIF, it's being invoked by one or more imported objects.
    Candidate object types include ...
    Graphical and mixed: EPS, PDF, DWG, DXF
    Text (insets): FM, MIF, RTF, DOC, perhaps others
    ______
    Can't help with the sep issue.
    Jul 18, 2011 11:45 AM   in reply to Misha Ko
    Thanks. If the font isn't found -- for whatever reason, in whatever kind of object -- could I do a workaround by installing the missing font?
    The optimal solution is to have the creator of the imported object either embed the font, or convert the text to outlines, and then re-save. Not all file formats support embedding, of course. EPS and PDF do.
    Plan B is to install the missing font on your local machine.
    Plan C, if the substitution is not causing a visible problem, is to either ignore it, or adjust your Frame font-mapping and Remember Missing Fonts options (which may or may not be helpful with some types of imported objects).
    MS Shell Dlg 2 isn't really a font at all ...
    What kind of objects are being imported that invoke this? (file format and content)
    If I had to guess, I'd suspect they were hand-crafted recreations of localized dialog boxes, using real MS screen fonts. If so, chances are that "substitute Times New Roman for" is not ideal. You might set the Frame font map to substitute Arial.
    Jul 18, 2011 12:46 PM   in reply to Misha Ko
    ... I guess it's possible I was doing some online research, looking up a supplier's recommended guidelines, or whatever, andcut and pasted a few words of text directly in to my doc.
    That would show up as a visible (local override) font declaration in the MIF.
    If you brought it in as a text inset (import by reference) from a .DOC or .RTF it would not be found in the MIF.
    MS Shell Dlg 2
    Due to the odd nature of this MS Registry hack, I'm wondering if that name, per se, would necessarily appear at all in the MIF.
    Jul 18, 2011 2:02 PM   in reply to Misha Ko
    Visible how?
    Save the .FM file in MIF format to a file named .mif.
    Open the .mif with a plaintext editor (Notepad will do).
    Search for the string "MS Shell".
    Examine the neighboring tags.
    As far as I know, Ctrl + F doesn't list "font" in the drop-down selections, among the search categories.
    A quick test of the Find dialog in Frame didn't seem to have any obvious way of searching for local font overrides by name. I'd be happy to be mistaken.
    I was just wondering what the "value of separation out of range" meant. Couldn't find much on it online.
    In your File > Print dialog, is
    [*] Print Separations
    selected?
    If not, I can't imagine what that alert might be related to.
    Jul 18, 2011 3:45 PM   in reply to Misha Ko
    An excellent freebie utility for future viewing (viewing, not editing) MIF files is MIFBrowse  by Graham Wideman. Even though it hasn't been updated in umptyump years, it works with any version of MIF. It's here:
    MIFBrowser
    Jul 18, 2011 4:46 PM   in reply to Misha Ko
    Is there a FM option for that character -- Ctrl Q + something, or esc + something?
    [Ctrl[q]]1
    I would typically create a variable for it:
    Definition: \xb1
    or, on the odd chance that your narrative font doesn't have the glyph, or you want the typeface style to match other symbols, plusminus also exists in the TT and T1 "Symbol" fonts. Assuming you have a Character Format named "Symbol", the var would be:
    Definition: <Symbol>\xb1<Default ¶ Font>
    For future reference, see:
    drive:\Program Files\Adobe\FrameMaker#.#\OnlineManuals
    file: Character_Sets.pdf
    That was at 7.0.
    I don't have a 9.0 install handy to check at the moment.
    _______
    And yes, you can fake plusminus as "+" with an underscore, except in this forum
    Jul 19, 2011 8:05 AM   in reply to Misha Ko
    On FM9, it's:
    drive:\Program Files\Adobe\FrameMaker9\Documents
    According to the Character_Sets.pdf there, the keyboard sequence Ctrl+q 1 was dropped at FM8. It's unclear if hex code \xb1 went with it.
    I also looked and found that there are separate character sets for different versions of FM. (Or maybe the character sets are the same, ...)
    Special character keystroke sequences were historically very different for Unix, Mac and Windows. In the past, the available characters might even have been different as well. Using hex codes in variables for these tended to minimize platform portability problems.
    However, with FM8, Unicode took over. I haven't really looked into whether or not it would be wiser to use Unicode code points once we migrate off FM7.1. Obviously, these would not backport to FM7.x or earlier, should that be an issue.
    Oct 3, 2011 10:27 AM   in reply to Misha Ko
    I got the MS Shell Dlg 2" Font is not available.  "Times New Roman" will be used in this session."  error recently, running Adobe FM 10 on Windows 7. I tried all kinds of solutions even trying to edit the Windows registry for the MS Shell Dlg 2 font which did not correct the problem. As mentioned in this thread, MS Shell Dlg 2 is not really a font, and so I couldn't search for it in the files. FM would not build the book with this error in 2 of my chapter files. Finally my colleague suggested I deslect Remember missing font names in the FM Preferences with no files open, open each file, let FM substitute MS Shell Dlg 2 to use Times Roman, then save the files. On reopening, I no longer got the "
    The "MS Shell Dlg 2" Font is not available.   "Times New Roman" will be used in this session." error.
    Oct 4, 2011 12:28 AM   in reply to Misha Ko
    Just or the record:
    Yes, if you copy and paste some characters from Windows’ Character Map utility you are likely to introduce as a side effect that ominous font. I seem to remember it helps to paste using Edit > Paste Special > Unicode Text.
    - Michael
    Nov 13, 2012 4:45 PM   in reply to Misha Ko
    a lot of great information here and yes, I'm seeing similar results to what others report.  It is suggested to tell FM to stop looking for missing fonts but that causes FM to lose the original font information in the document.  That might be ok, but folks should be aware of what is happening to their doc.
    the MS Shell Dlg  and MS Shell Dlg 2 are face names used for mapping.  Depending on what Windows version you're using the referenced font is different.
    To see what is installed on your machine get to a run prompt (window button + r) then type "control fonts" without the quotes.  That will show you what is installed on your machine.
    To see what is being mapped to MS Shell Dlg and Dlg 2 get to a run prompt and type regedit (registry editor BE CAREFUL HERE)  go to
    HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\Current Version\FontSubstitutes and review what font is being referenced
    I'm on Windows 7 so MS Shell Dlg is MicroSoft San Seriff and MS Shell Dlg 2 is Tahoma
