Flame \'06
PDF w/layers - layers not showing in CS5
Jul 19, 2011 3:06 PM
I have a pdf file that was created in Adobe Illustrator and it has several layers that I can see when opened with Acrobat. When I try to open the file with
Photoshop CS5, I see the image as only one layer instead of seeing all the layers. Is there a way I view all the layers in Photoshop?
Thanks for any help,
Richard
    Jul 19, 2011 3:54 PM   in reply to Flame \'06
    Illustrator saves it's layers in PDF in a way that only Illustrator can read.
    Photoshop saves it's layers in PDF in a way that only applications that can read PSD can read.
    The layer data is not the same, nor is it sharable with other applications.
    You would need to export your Illustrator document as a PSD file, with layers -- but that may change the appearance because Illustrator's transparency model is not the same as other application's transparency model.
    Jul 19, 2011 11:08 PM   in reply to Flame \'06
    PDF layers are something different than PS layers and again then it makes a difference if the editable data was created by AI or inDesign for instance. As C.C. already said, you need to properly export your document to PSD from AI to use those layers in PS.
    Mylenium
