Any tips on how to extract an embedded bitmap at its original pre-embedded resolution from an AI file?
Here's another method:
First removing any other elements or clipping paths. Select the image and in the Links pane flyout choose Placement Options and pick File Dimensions. If your image is larger than your artboard, you will have to make your artboard larger than the image.
Then to save your .ai file as a .pdf (Illustrator default = no downsampling or compression). Then open the the file in Acrobat Professional and using the Touch Up image tool to select the image and open it in Photoshop. Then you can "save as" the Photoshop file to whatever format you wish.
Holy smokes, the years decades I've been using these apps w/o noticing how easy it was to extract embedded images from AI. All other methods seem silly (especially the ways I've been doing it).
I need someone like Scott to just watch me work for an hour, then tell me all the essential tricks I have never learned.
North America
Asia Pacific
