Which monitor for accurate color management?
Aug 1, 2011 8:56 PM
I shoot digital product and food photography using a mac powerbook. I've been using a LaCie CRT (yes, I said CRT) monitor for fine tuning my photos. It has finally started acting up so I'm ready for a new monitor. Can anyone recommend a dependable monitor that has color, brightness and contrast controls for use with establishing color managed profiles using eye1 macbeth (now that company is called something else which I can not remember at the moment). Obviously it needs to be accurate when it comes to color, brightness and contrast as well.
I ended up using my laptop screen this past shoot cause I had no other choice - but it made me really nervous.....
thanks -
    Aug 1, 2011 9:22 PM   in reply to marshmallow88
    First of all, my sincere condolences for your loss.  Losing your last high-end CRT is a traumatic loss.  I'm still hanging on to two (2) of them!  (Knock on wood!)
    Highly recommended monitors:
    The NEC 2690 and 2490.
    You want to use the SpectraView II software to conduct all the work internally and use GammaComp and ColorComp.
    If Andrew Rodney chimes in with updated recommendations, listen to his advice.
    ____________
    Wo Tai Lao Le
    我太老了
  • Andrew Rodney
    Apr 16, 2009
    Aug 2, 2011 6:45 AM   in reply to marshmallow88
    I’d look into the newer line of NEC SpectraView’s (PA series). You’ll want to calibrate them with their insturment which is mated for the wide gamut panel and use their SpectraView II software (or Multiprofiler without an instrument, your pick).
    Aug 2, 2011 11:07 AM   in reply to Tai Lao
    That's probably traditional chinese wisdom.
    Hundred thousands of people are using correctly calibrated monitors.
    Best regards --Gernot Hoffmann
    Aug 2, 2011 8:44 PM   in reply to marshmallow88
    marshmallow88 wrote:
    Trying not to spend extra money - is the old Gretag Macbeth profiling
    software/system not good with the recommended monitors?
    Do you want honest advice and recommendations or are you just looking for reassurance?
    If the former, just see the above posts.  If the latter, I wouldn't know what to tell you.
    ____________
    Wo Tai Lao Le
    我太老了
    Aug 2, 2011 8:48 PM   in reply to Gernot Hoffmann
    Gernot Hoffmann wrote:
    That's probably traditional chinese wisdom…
    Vielleicht das auch…
  • Andrew Rodney
    Apr 16, 2009
    Aug 3, 2011 6:33 AM   in reply to marshmallow88
    The instrument may be supported in SpectraView II depending on how old it is. But you want to drive the calibration and profile process on a SpectraView II using their software to take full control of the panel. You do not want to use the GretagMacbeth software to calibrate the SpectraView II system.
  • Andrew Rodney
    Apr 16, 2009
    Sep 14, 2011 5:02 PM   in reply to marshmallow88
    If you can’t afford or justify the PA, go P221W with software and instrument. Its the NEC entry level SpectraView but sill provides a lot of bang for the buck.
  • Andrew Rodney
    Apr 16, 2009
    Sep 14, 2011 5:18 PM   in reply to marshmallow88
    The big differences is the PA is a IPS display and the P221W isn’t. The PA is a newer, more expensive panel that access PIP, can access the newer Multiprofiler software.
  • Andrew Rodney
    Apr 16, 2009
    Sep 14, 2011 5:40 PM   in reply to marshmallow88
    If you can afford the PA series, get that, if not, get the P221W.
