Disabling auto-complete on Spark ComboBox
Aug 4, 2011 5:36 AM
I want to disable the auto-completing of text entered into a ComboBox, but still have it match the text against items in the DropDownList. Is there any easy way to do this?
    Aug 4, 2011 5:43 AM   in reply to RandomReado
    I think you'll have to extend the component to make this work.  I don't believe there is a property to control this behavior.
    May 6, 2012 4:27 PM   in reply to RandomReado
    Those "functionalities" are implemented by the private function processInputField() and the mx_internal function applySelection()
    of the ComboBox component. They are either private of mx_internal so you can't override them. I created a new AS class that extends extends DropDownListBase and implements IIMESupport, just like the Spark ComboBox and tweaked the functions, for example I commented this lines:
    // textInput.selectAll();
    // textInput.insertText(itemString);
    Hope that helps!!
    Sep 11, 2012 5:30 AM   in reply to nvhdab
    Simply create you new combobox class and override the findStringLoop function, it should always return -1 to prohibit the fincding of matching items (for autocomplete reasons).
    Code is the following:
                         * Disabel the autocomplete option on Spark Combobox
                        mx_internal override function findStringLoop(str:String, startIndex:int, stopIndex:int):Number
                             return -1;
    May 17, 2013 9:33 AM   in reply to RandomReado
    The easiest solution for me was to use the existing itemMatchingFunction attribute on ComboBox and create a function like the one below retuning an empty Vector array:
    protected function comboDisableMatchingFunction(comboBox:ComboBox, inputText:String):Vector.<int>
                                            return new Vector.<int>();
    May 18, 2013 3:12 PM   in reply to the_brownfoot
    @the_brownfoot
    That is the same solution as overriding findStringLoop() method. Hopefully Flex is open source so we can invent workarounds easily
