I read Raymond Camden's blog post about triple related selects and I'm trying to implement a solution of my own. I can only get the first dropdown to populate and am getting three bind errors "Bind Failed, element not found: SelState ..." for the first two and then "Bind Failed, element not found: SelDestination ... " for the last.
My code looks accurate (to me anyway) but clearly its not working.
Can someone please help me debug this?
<cfform name="Localiza">
<table>
<tr>
<td width="100">State:</td>
<td width="150">
<cfselect name="SelState" bind="cfc:_fc_cfc_triple.GetState()"
display="misc_state" value="misc_state" BindOnLoad="true"/></td></tr>
<tr>
<td width="100">County:</td>
<td width="150">
<cfselect name="SelCounty" bind="cfc:_fc_cfc_triple.GetCounty({SelState})"
display="destination_county" value="destination_county" BindOnLoad="false"/></td></tr>
<tr>
<td width="100">Destination:</td>
<td width="150">
<cfselect name="SelDestination" bind="cfc:_fc_cfc_triple.GetDestination({SelState},{SelDestination})"
display="destination_name" value="destination_id" BindOnLoad="false"/></td></tr>
</table>
</cfform>
The form is above, the cfc (_fc_cfc_triple.cfc) is below
<cfcomponent>
<cffunction name="GetState" access="remote" returnType="query">
<cfquery name="LstState" datasource="mydsn">
SELECT misc_state
FROM states_misc
ORDER BY misc_state ASC
</cfquery>
<cfreturn LstState>
</cffunction>
<cffunction name="GetCounty" access="remote" returnType="query">
<cfargument name="misc_state" type="any" required="true">
<cfif #ARGUMENTS.misc_state# EQ "">
<cfset LstCounty="">
<cfelse>
<cfquery name="LstCounty" datasource="mydsn">
SELECT DISTINCT destination_county
FROM destinations
WHERE destination_state = #ARGUMENTS.misc_state#
ORDER BY destination_county ASC
</cfquery>
</cfif>
<cfreturn LstCounty>
</cffunction>
<cffunction name="GetDestination" access="remote" returnType="query">
<cfargument name="destination_county" type="any" required="true">
<cfif #ARGUMENTS.misc_state# EQ "" OR #ARGUMENTS.destination_county# EQ "">
<cfset LstDestination="">
<cfelse>
<cfquery name="LstDestination" datasource="mydsn">
SELECT destination_id,destination_name
FROM destinations
AND destination_county = #ARGUMENTS.destination_county#
ORDER BY destination_name ASC
</cfquery>
</cfif>
<cfreturn LstDestination>
</cffunction>
</cfcomponent>
For the last two selects, if the arguments are empty it will probably fail as the return type is expecting a query object and not a string. You can either change the functions as follows to make them return query objects when the arguments are empty, or make sure that there is no empty value in your State drop-down upon first load.
The code works for me otherwise.
<cfset LstCounty = queryNew("destination_county","varchar")>
<cfelse>
FROM destinations
</cfquery>
</cfif>
</cffunction>
<cfset LstDestination = queryNew("destination_id,destination_name","integer,varchar")>
<cfelse>
FROM destinations
</cfquery>
</cfif>
</cffunction>
I continue to tinker with this but I cannot understand why all three binds fail. I changed my initial query so that a result has to be displayed and that didn't work.
I'm beginning to wonder if I should abandon my approach and just use the downloaded code from the Jedi's site and fill that .cfm include with real data??
I'd rather not do that. Can anyone see what is wrong with my approach?
Probably trying to keep all the balls in the air before you've learned how to juggle could be the issue here.
Do this:
* Abandon the code you currently have;
* start again. Write some code that gets a single bind working to spec. Do not worry about your ultimate requirement, just hard-code mark-up & sample data and everything you need to make the code as simple as possible, and as self-contained as possible;
* copy that code, putting the original aside so you can return to it if you need to;
* on the copy of the code, augment it to get the second bind working. Do not think about the third bind until you have the second one working;
* copy that code and save a back-up of it;
* augment the copy to get the third bind working;
* put that code aside;
* apply the techniques that you should now be comfortable with to your actual requirement, implementing one enhancement at a time until it works 100% before moving onto the next bit.
At no point move to the next step before the code in the current step is working 100% and you understand it 100%. At any step you cannot progress, post the code here, post the results of running the code here, post any CF or JS error messages here. The code you post here should be able to be copy and pasted from your post, saved to file(s) and run. So no DB requirements, no calls to methods you don't provide the code for, etc.
Adam
I have been tinkering with the data that's in the included .cfm file that contains the <cfscript>.
Things are working well for me... However, my last dropdown is the problem child. The reason I wanted a triple select in the first place is that my destinations table (the third dropdown) has over 300k rows. So I can't load it up front in the <cfscript> because it takes way too long.
What can I do? Is there some way I can wait to query the table until the first two dropdowns are populated?
Answered my own q. Man... that was fun. Ok first of all, thank you Raymond for posting the triple select blog post on your Jedi blog. What I ended up doing was altering the script so that I had query data returned for the first two selects. Since my third select was the one that queried that large table, I didn't use the script but instead queried the database. That's it! Simple and working well.
Please let me know if you'd like me to post the code and I will.
Adam Cameron. wrote:
Good work.
It'd probably be helpful for other people encountering the same problem if you posted your code.
Adam
<cfquery name="get_states" datasource="mydsn">
SELECT state_id,state
FROM states
ORDER BY state
</cfquery>
<cfquery name="get_counties" datasource="mydsn">
SELECT county_id,state_id,county
FROM counties
ORDER BY state_id,county_id
</cfquery>
<cfquery name="get_destinations" datasource="mydsn" maxrows="1">
SELECT state_id,county_id,destination_id,destination_name
FROM destinations
WHERE destination_id = '0'
</cfquery>
<cfscript>
State = QueryNew("state_id,state","Integer,Varchar");
for(i=1; i LTE get_states.RecordCount; i=i+1){
newRow = QueryAddRow(State);
QuerySetCell(State, "state_id", #get_states.state_id[i]#);
QuerySetCell(State, "state", "#get_states.state[i]#");
County = QueryNew("state_id, county_id, county", "Integer, Integer, Varchar");
for(i=1; i LTE get_counties.RecordCount; i=i+1){
newRow = QueryAddRow(County);
QuerySetCell(County, "state_id", #get_counties.state_id[i]#);
QuerySetCell(County, "county_id", #get_counties.county_id[i]#);
QuerySetCell(County, "county", "#get_counties.county[i]#");
Destination = QueryNew("state_id, county_id, destination_id, destination_name", "Integer, Integer, Integer, Varchar");
for(i=1; i LTE get_destinations.RecordCount; i=i+1){
newRow = QueryAddRow(Destination);
QuerySetCell(Destination, "state_id", #get_destinations.state_id[i]#);
QuerySetCell(Destination, "county_id", #get_destinations.county_id[i]#);
QuerySetCell(Destination, "destination_id", #get_destinations.destination_id[i]#);
QuerySetCell(Destination, "destination_name", "#get_destinations.destination_name[i]#");
</cfscript>
<cfargument name="State" type="any" required="true">
<cfargument name="County" type="any" required="true">
<cfif ARGUMENTS.State EQ "" OR ARGUMENTS.County EQ "">
<cfset LstDestination = QueryNew("state_id, county_id, destination_id, destination_name", "Integer, Integer, Integer, Varchar")>
<cfelse>
SELECT state_id, county_id, destination_id, destination_name
FROM destinations
WHERE state_id = #ARGUMENTS.State# AND
county_id = #ARGUMENTS.County#
</cfquery>
</cfif>
</cffunction>
Hi Idesdema,
I'm working on a year/make/model/option/option2 related search and came across your post. I know its been a while but do you have the form that goes with the post so i can take a look at how to reference the cfc properly?
I have tried so many tutorisals and none have worked. At this point i built a database to match your code so i can test to make sute i have a good idea before i convert it to my automotive app. Thanks!
Cheers,
Aaron
Did you ever get a error on the returnType="query"? It says "The value of the attribute QUERY is invalid. The 'Query' attribute must be defined if the 'Value', 'Display', or 'Group' attributes are defined."
<cfelse>
<cfquery name="LstDestination" datasource="" username="" password="">
FROM destinations
</cfquery>
</cfif>
</cffunction>
Are you including the .cfm file in the cfc that initially declares that LstDestination? Something like...
(in the included file before your functions)
LstDestination = QueryNew("state_id, county_id, destination_id, destination_name", "Integer, Integer, Integer, Varchar");
for(i=1; i LTE get_destinations.recordcount; i=i+1){
newRow = QueryAddRow(LstDestination);
QuerySetCell(LstDestination,"state_id", #get_destinations.state_id[i]#);
QuerySetCell
and so on for the other columns...
I have it in my cfc named "_fc_cfc_triple.cfc" saved in the same directory as the form. I haven't really used CFC's until this week. How do i include it properly? I wonder if its even loading it.
I thought maybe the form was calling it in the select tag:
<cfform>
<table>
<tr>
<td width="150">
<cfselect name="SelState" bind="cfc:_fc_cfc_triple.GetState()" display="misc_state" value="misc_state" BindOnLoad="true"/></td></tr>
<tr>
<td width="150">
<cfselect name="SelCounty" bind="cfc:_fc_cfc_triple.GetCounty({SelState})" display="destination_county" value="destination_county" BindOnLoad="false"/></td></tr>
<tr>
<td width="150">
<cfselect name="SelDestination" bind="cfc:_fc_cfc_triple.GetDestination({SelState},{SelDestination})" display="destination_name" value="destination_id" BindOnLoad="false"/></td></tr>
</table>
</cfform>
CFC:
<cfelse>
FROM destinations
</cfquery>
</cfif>
</cffunction>
The code I roughed out in #16 is what should in a seperate .cfm file that is included within your .cfc.
So, my code is very similar to yours, but I have a <cfinclude template="..."> in the .cfc file that first establishes the three queries for when the select boxes have yet to be changed. You should have something similar.
Thank you. Do i wrap that with a javascript tag?
Dan Bracuk wrote:
I think you are better off with 3 functions, one for each select. It would be a lot simpler.
Also, if you read the entire thread, you will notice some excellent advice from Adam Cameron. It's the one that mentions juggling. The approach he suggests is the one I usually take.
Thank you, i will start with a single select this morning and try and get it working properly.
idesdema wrote:
That is how mine is setup... one function for each dropdown. I'm assuming Aaron's is that way as well. And for the record I did take Adam's advice (long long ago when I was working on this) and that's how I arrived at my triple select. It works well and is efficient.
Thanks, mine is set up that way as well. I'm going to start over and go peice by piece and see if that makes more sense.
idesdema wrote:
Let me know if u want my code if u get stuck. I'll zip and send.
Yes Please...
I have broken it down to the following, but i'm still confused. I don't get errors anymore, but i don't get any select options either.
index.cfm:
<cfform name="RabbitFoot">
<table>
<tr>
<td width="100">Select Year:</td>
<td width="150">
<cfselect name="SelYears" bind="cfc:vehicles.GetYear()" BindOnLoad="true"/>
</td>
</tr>
</table>
</cfform>
include QryYears.cfm:
<cfquery name="GetYearRange" datasource="" username="" password="">
SELECT DISTINCT YearRange
FROM ExactFit2012
ORDER BY YearRange
</cfquery>
<cfscript>
YearRange = QueryNew("YearRange","Varchar");
for(i=1; i LTE getYearRange.RecordCount; i=i+1){
newRow = QueryAddRow(YearRange);
QuerySetCell(YearRange, "YearRange", "#GetYearRange.YearRange[i]#");
</cfscript>
CFC:
<cfinclude template="QryYears.cfm">
<cffunction name="GetYear" access="remote" returnType="query">
<cfargument name="GetYearRange" type="any" required="true">
<cfif ARGUMENTS.GetYearRange EQ "">
<cfset LstYears = QueryNew("YearRange", "Varchar")>
<cfelse>
<cfquery name="GetYearRange" dbtype="query" datasource="GriffinDSN" username="aaron_Griffin2009" password="Griffin1">
FROM ExactFit2012
ORDER BY YearRange
</cfquery>
</cfif>
<cfreturn LstYears>
</cffunction>
I don't know if i'm supposed to have two queries that are the same, or if the second query was supposed to be for my next set of select options.
The first part, the form:
<cfform name="destination_jump" method="post" action="redirect.cfm?redirect_indicator=destination_jump">
<table cellpadding="4" cellspacing="0" border="0">
<tr>
<tr>
<td align="right" valign="top">
State:
</td>
<td align="left">
<cfselect class="dropdown" name="jump_state" bind="cfc:_cfc_triple.get_states()" display="state" value="state_id" bindonload="true"/>
</td>
</tr>
<tr>
County:
</td>
<td align="left">
<cfselect class="dropdown" name="jump_county" bind="cfc:_cfc_triple.get_counties({jump_state})" display="county" value="county_id"/>
</td>
</tr>
<tr>
Destination:
</td>
<td align="left">
<cfselect class="dropdown" name="jump_desty" bind="cfc:_cfc_triple.get_destinations({jump_state},{jump_county},{activity})" display="destination_name" value="destination_id" required="yes" message="Please select a destination."/>
</td>
</tr>
<tr>
<td valign="top" align="center" colspan="2">
<cfinput type="submit" validate="submitonce" name="save" value="GO">
</td>
</tr>
</table>
</cfform>
The second part, the cfc file:
<cfcomponent>
<cfinclude template="cfc-includes/_cfc_triple.cfm">
<cffunction name="get_states" access="remote" returnType="query">
<cfquery name="LstState" dbtype="query">
SELECT state_id, state
FROM State
ORDER BY state
</cfquery>
<cfreturn LstState>
</cffunction>
<cffunction name="get_counties" access="remote" returnType="query">
<cfif ARGUMENTS.State EQ "">
<cfset LstCounty = QueryNew("state_id, county_id, county", "Integer, Integer, Varchar")>
<cfelse>
<cfquery name="LstCounty" dbtype="query">
SELECT state_id, county_id, county
FROM County
ORDER BY county
</cfquery>
</cfif>
</cffunction>
<cffunction name="get_destinations" access="remote" returnType="query">
<cfargument name="activity" type="any" required="true">
<cfelse>
SELECT DISTINCT state_id, county_id, destination_id, CONCAT_WS(' - ',destination_name,destination_county) destination_name
FROM #ARGUMENTS.activity#_destinations
</cfquery>
</cfif>
</cffunction>
</cfcomponent>
And lastly, the cfm include for the cfc:
FROM tbl_states
ORDER BY state
</cfquery>
FROM tbl_counties
</cfquery>
FROM tbl_destinations
</cfquery>
<cfscript>
</cfscript>
Thank you very much!
Can I ask if you ever got the following error on the query using the " display="state" value="state_id" " within the select tags?
On my last couple tries I got the "The value of the attribute QUERY is invalid. The 'Query' attribute must be defined if the 'Value', 'Display', or 'Group' attributes are defined." error so I went to Ray's blog and another developer had taken them out completely to fix the error, even though Ray never got that error on his local servers. I'm curious as to why we got them but ray and others didn't.
We are using CF8 but we are shared hosting so I’m thinking it might be some preference in the CF settings.
Thanks!
Hi Again,
All of my data is in one table with one ID so i needed to modify the included page and the CFC queries and the script below to refelct that. I don't get errors but still no data being inserted into the dropdowns.
<cfquery name="get_years" datasource="DSN">
SELECT YearRange
FROM ExactFit2012
ORDER BY YearRange
</cfquery>
<cfquery name="get_makes" datasource="DSN">
SELECT make
FROM ExactFit2012
ORDER BY Make
</cfquery>
<cfquery name="get_models" datasource="DSN">
SELECT model
FROM ExactFit2012
ORDER BY model
</cfquery>
Origional Code:
FROM tbl_states
ORDER BY state
</cfquery>
FROM tbl_counties
</cfquery>
</cfquery>
<cfscript>
Year = QueryNew("YearRange","Varchar");
for(i=1; i LTE get_years.RecordCount; i=i+1){
newRow = QueryAddRow(Year);
QuerySetCell(Year, "YearRange", "#get_years.YearRange[i]#");
make = QueryNew("YearRange, make", "Varchar, Varchar");
for(i=1; i LTE get_makes.RecordCount; i=i+1){
newRow = QueryAddRow(make);
QuerySetCell(make, "YearRange", #get_makes.YearRange[i]#);
QuerySetCell(make, "Make", #get_makes.make[i]#);
Model = QueryNew("YearRange, make, model", "Varchar, Varchar, Varchar");
for(i=1; i LTE get_models.RecordCount; i=i+1){
newRow = QueryAddRow(model);
QuerySetCell(model, "YearRange", #get_models.YearRange[i]#);
QuerySetCell(model, "make", #get_models.make[i]#);
QuerySetCell(model, "model", #get_models.model[i]#);
</cfscript>
Origional Code:
<cfscript>
</cfscript>
I deleted all the references to the _id fields from the code so that it might work with my data but i think i may have needed that.
Hi Idesdema & Dan,
Back Again, still not working for me.
I tried breaking it down to a single select for learning purposes. I keep getting the error "The value of the attribute QUERY is invalid. The 'Query' attribute must be defined if the 'Value', 'Display', or 'Group' attributes are defined." unless i remove the "display" and "value" attributes inside of the select tag. When i do it stops the error but i get no results. For some reason i think those need to be there as a reference to the data and could be the reason i'm not seeing results, but i'm not certain. What do you think?
Form:
<cfform name="_jump" method="post" action="">
<tr>
<tr>
Year Range:
</td>
<td align="left">
</td>
</tr>
</table>
</cfform>
CFC:
<cfcomponent>
<cfinclude template="_cfc_triple.cfm">
<cfquery name="LstState" dbtype="query" datasource="GriffinDSN">
SELECT ID, YearRange
FROM ExactFit2012
ORDER BY YearRange
</cfquery>
<cfreturn LstState>
</cffunction>
</cfcomponent>
Include:
<cfquery name="get_states" datasource="GriffinDSN">
FROM ExactFit2012
ORDER BY YearRange
</cfquery>
<cfscript>
State = QueryNew("ID,YearRange","Integer,Varchar");
QuerySetCell(State, "id", #get_states.id[i]#);
QuerySetCell(State, "YearRange", "#get_states.YearRange[i]#");
</cfscript>
Your error message is being generated because you are running a query of queries against a database table.
It appears that you are running way too much code in order to get what you want. For example, you are running a database query called get_states and then looping though it to produce a CF query called state. I'm not sure what that's all about.
I also don't know why there is an included file for the query. If you need a query object that's available to more than one function, just run the code in the cfc file, outside of any function.
Going back to the juggling analogy, if it were me, I'd test my cfc functions with either cfinvoke or createobject syntax before attempting to use them with bind syntax.
Thanks! I will keep trying ![]()
Hi Dan i tried using the CFInvoke Below. I haven't tried using these types of tags before and am googling examples to modify and use.
Here is mine:
CFC: Named Components
<cfcomponent displayname="Years" hint="ColdFusion Component for Getting Vehicle Years">
<cffunction name="retrieveYears" hint="Gets all years from the database" returntype="query">
<cfquery name="getYears" datasource="GriffinDSN">
FROM ExactFit2012
ORDER BY YearRange
</cfquery>
<cfreturn getYears>
</cffunction>
</cfcomponent>
Invoke:
<cfinvoke component="components.years" method="retrieveYears" returnvariable="allYears"></cfinvoke>
<cfoutput query="allYears">
#YearRange#
</cfoutput>
North America
Asia Pacific
