"Date Modified" for all files being changed if "Automatically write to XMP" is on
Aug 9, 2011 9:21 PM
Recently upgraded from LR3 (v3.4.1) from LR2 on OSX 10.6.8 and have always had Catalog Settings > Automatically write changes into XMP turned on.
When browsing existing JPG files in my Library (no Develop changes, no keywording, no Presets, no Import), LR3 is writing to disk — i.e., when I look at files in Finder, almost every viewed file’s “Date Modified” is being set to today’s date and time. (It actually creates a .swp file, then changes it's name back to .jpg)
This is really bad, as it's making it impossible for me to use Finder to figure out when I last worked with a file, it is triggering needless Time Machine and Backblaze backups, and unnecessarily churning my disk.
If I turn off "Automatically write..." this behavior stops. Per David Marx at thelightroomlab.com, I tried turning off this preference, manually doing a "Save Metadata to File" for all files, letting that complete, then turning the preference back on. This does not solve the problem.
Per a suggestion at photoshop.com, I used ExifTool to see what changes LR was writing to a sample file; from the diff below, you can see that LR is adding a bunch of new fields as well as moving other fields around. But my point is that LR3 should never overwrite a file on disk if all I am doing is browsing thru them.
Is anyone else seeing this? Any ideas would be greatly appreciated!
-- David
diff Exif5609_original Exif5609_update
2c2
< FileName: DSC_5609_original.JPG
> FileName: DSC_5609_update.JPG
5,6c5,6
< FileModifyDate: 2009:11:27 21:32:54-08:00
< FilePermissions: rwxr-xr-x
> FileModifyDate: 2011:08:07 22:06:47-07:00
> FilePermissions: rw-r--r--
27a28,29
> ShutterSpeedValue: 1/200
> ApertureValue: 7.1
55d56
< SerialNumber: 3209521
75d75
< Lens: 18-200mm f/3.5-5.6
185,188d184
< UserComment:
< SubSecTime: 00
< SubSecTimeOriginal: 00
< SubSecTimeDigitized: 00
211a208,299
> XMPToolkit: Adobe XMP Core 5.2-c004 1.136881, 2010/06/10-18:11:35
> CreatorTool: Ver.1.00
> MetadataDate: 2011:08:07 22:06:47-07:00
> LensInfo: 18-200mm f/3.5-5.6
> Lens: 18.0-200.0 mm f/3.5-5.6
> ImageNumber: 26634
> RawFileName: DSC_5609.JPG
> SavedSettingsName: Import
> SavedSettingsType: Snapshot
> SavedSettingsParametersVersion: 6.4.1
> SavedSettingsParametersProcessVersion: 5.0
> SavedSettingsParametersWhiteBalance: As Shot
> SavedSettingsParametersIncrementalTemperature: 0
> SavedSettingsParametersIncrementalTint: 0
> SavedSettingsParametersExposure: 0.00
> SavedSettingsParametersShadows: 0
> SavedSettingsParametersBrightness: 0
> SavedSettingsParametersContrast: 0
> SavedSettingsParametersSaturation: 0
> SavedSettingsParametersSharpness: 0
> SavedSettingsParametersLuminanceSmoothing: 0
> SavedSettingsParametersColorNoiseReduction: 0
> SavedSettingsParametersChromaticAberrationR: 0
> SavedSettingsParametersChromaticAberrationB: 0
> SavedSettingsParametersVignetteAmount: 0
> SavedSettingsParametersShadowTint: 0
> SavedSettingsParametersRedHue: 0
> SavedSettingsParametersRedSaturation: 0
> SavedSettingsParametersGreenHue: 0
> SavedSettingsParametersGreenSaturation: 0
> SavedSettingsParametersBlueHue: 0
> SavedSettingsParametersBlueSaturation: 0
> SavedSettingsParametersFillLight: 0
> SavedSettingsParametersVibrance: 0
> SavedSettingsParametersHighlightRecovery: 0
> SavedSettingsParametersClarity: 0
> SavedSettingsParametersDefringe: 0
> SavedSettingsParametersHueAdjustmentRed: 0
> SavedSettingsParametersHueAdjustmentOrange: 0
> SavedSettingsParametersHueAdjustmentYellow: 0
> SavedSettingsParametersHueAdjustmentGreen: 0
> SavedSettingsParametersHueAdjustmentAqua: 0
> SavedSettingsParametersHueAdjustmentBlue: 0
> SavedSettingsParametersHueAdjustmentPurple: 0
> SavedSettingsParametersHueAdjustmentMagenta: 0
> SavedSettingsParametersSaturationAdjustmentRed: 0
> SavedSettingsParametersSaturationAdjustmentOrange: 0
> SavedSettingsParametersSaturationAdjustmentYellow: 0
> SavedSettingsParametersSaturationAdjustmentGreen: 0
> SavedSettingsParametersSaturationAdjustmentAqua: 0
> SavedSettingsParametersSaturationAdjustmentBlue: 0
> SavedSettingsParametersSaturationAdjustmentPurple: 0
> SavedSettingsParametersSaturationAdjustmentMagenta: 0
> SavedSettingsParametersLuminanceAdjustmentRed: 0
> SavedSettingsParametersLuminanceAdjustmentOrange: 0
> SavedSettingsParametersLuminanceAdjustmentYellow: 0
> SavedSettingsParametersLuminanceAdjustmentGreen: 0
> SavedSettingsParametersLuminanceAdjustmentAqua: 0
> SavedSettingsParametersLuminanceAdjustmentBlue: 0
> SavedSettingsParametersLuminanceAdjustmentPurple: 0
> SavedSettingsParametersLuminanceAdjustmentMagenta: 0
> SavedSettingsParametersSplitToningShadowHue: 0
> SavedSettingsParametersSplitToningShadowSaturation: 0
> SavedSettingsParametersSplitToningHighlightHue: 0
> SavedSettingsParametersSplitToningHighlightSaturation: 0
> SavedSettingsParametersSplitToningBalance: 0
> SavedSettingsParametersParametricShadows: 0
> SavedSettingsParametersParametricDarks: 0
> SavedSettingsParametersParametricLights: 0
> SavedSettingsParametersParametricHighlights: 0
> SavedSettingsParametersParametricShadowSplit: 25
> SavedSettingsParametersParametricMidtoneSplit: 50
> SavedSettingsParametersParametricHighlightSplit: 75
> SavedSettingsParametersSharpenRadius: +1.0
> SavedSettingsParametersSharpenDetail: 25
> SavedSettingsParametersSharpenEdgeMasking: 0
> SavedSettingsParametersPostCropVignetteAmount: 0
> SavedSettingsParametersGrainAmount: 0
> SavedSettingsParametersLensProfileEnable: 0
> SavedSettingsParametersLensManualDistortionAmount: 0
> SavedSettingsParametersPerspectiveVertical: 0
> SavedSettingsParametersPerspectiveHorizontal: 0
> SavedSettingsParametersPerspectiveRotate: 0.0
> SavedSettingsParametersPerspectiveScale: 100
> SavedSettingsParametersConvertToGrayscale: False
> SavedSettingsParametersToneCurveName: Linear
> SavedSettingsParametersCameraProfile: Embedded
> SavedSettingsParametersCameraProfileDigest: D6AF5AEA62557FCE88BC099788BBD3CC
> SavedSettingsParametersLensProfileSetup: LensDefaults
> SavedSettingsParametersToneCurve: 0, 0, 255, 255
> IPTCDigest: d41d8cd98f00b204e9800998ecf8427e
228,230d315
< SubSecCreateDate: 2009:11:27 21:32:54.00
< SubSecDateTimeOriginal: 2009:11:27 21:32:54.00
< SubSecModifyDate: 2009:11:27 21:32:54.00
