HELP would be awesome!!
Aug 10, 2011 8:20 AM
Hi guys !!
I am working o a jargon buster for a college project.
I have written up an (External) XML document like this:
<Items>
      <Query>Rip</Query>
       <answer>to copy files from a disc onto a computer</answer>
</Items>
Basically the user inputs their query into a editable text field and then flash searches the xml for the query and returns an
answer into a readable text field below.
My problem is how do I get flash to do that??
Thanks in advanced.
    Aug 22, 2011 8:55 AM   in reply to Gaff2156
    Hi
    First and most difficult is to be able to Search on whatever the User types in - this is not the most secure or easily searchable method.
    I'd suggest; to make life easier on yourslf - limit the Search criteria by using a drop-down list populated with your <query>Rip</query>
    The User is then limited only to the selection in the list  - and the result can be instantly displayed in a dynamic textfield.
    Hope it helps
    Aug 22, 2011 1:46 PM   in reply to Gaff2156
    Hi
    The drop-down list would be DYNAMIC - automatically populated by your XML.
    Google 'comboBox dataProvider'
    Hope it Helps
    Aug 22, 2011 3:06 PM   in reply to Gaff2156
    OK Try this
    Drag a ComboBox from the Components Panel onto the Stage and give it a Instance name of combo in the Properties Panel.
    Create a Dynamic TextField on the Stage with an Instance name of answer in the Properties Panel.
    Copy and Paste this into the Actions Panel.
    import flash.net.URLLoader;
    import flash.net.URLRequest;
    var xml:XML;
    var urlRequest:URLRequest = new URLRequest("jargonBuster.xml");
    var urlLoader:URLLoader = new URLLoader(urlRequest);
    urlLoader.load(urlRequest);
    urlLoader.addEventListener(Event.COMPLETE, xmlDataLoaded,false,0,true);
    function xmlDataLoaded(e:Event)
    xml = new XML(e.target.data);
    for each(var qry:XML in xml.items.Query)
         combo.addItem({label: qry});
    answer.text = xml.items[0].answer;
    combo.addEventListener(Event.CHANGE, comboChanged, false, 0, true);
    function comboChanged(e:Event)
        answer.text = xml.items[e.target.selectedIndex].answer;
    jargonBuster.xml looks like this:-
    <?xml version="1.0"?>
    <jargonBuster>
      <items>
        <Query>HDD</Query>
        <answer>Hard Disk Drive</answer>
      </items>
      <items>
        <Query>USB</Query>
        <answer>Universal Serial Bus</answer>
      </items>
      <items>
        <Query>Rip</Query>
      </items>
    </jargonBuster>
    Now when you select and item in the list the answer appears in the textfield.
    Hope it helps.
    Aug 23, 2011 6:50 AM   in reply to Gaff2156
    Glad it helped:-
    But now your asking for a Predictive Text System - I think you would have to implement a Dictionary based lookup system.
    I'm not familiar with this so not very helpful there.
    However: you could extend the drop-down list method -
    Add a Category Attribute to your jargonBuster.xml this would then be your fisrt choice drop-down.
    Such as: Email
                   Hardware
                   Internet
                   Software
    <item cat="Email">
    <query>Spam</query>
    <answer>Unsolicited Email</answer>
    </item>
    <item cat="Hardware">
    <query>HDD</query>
    <item cat="Email">
    <query>Junk Mail</query>
    <answer>Like Spam - but more annoying</answer>
    </item>
    Then in a second drop-down list you can have all the queries related to the choice in the first list.
    I am not trying to dissuade you from the way you want to do it - its just most systems use this type of drill-down method.
    Hope it helps
