Hi everyone,
I developped a Custom Component that is trying to retrieve a list of task (List<TaskRow>) assigned to a specific user (passed as parameter).
I understood that I need to connect to the server with his username and password in order to use the TaskManagerQueryService.taskList() and get his tasks.
My problem is that when I use this code inside my DSC :
Properties connectionProps = new Properties();
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAULT _SOAP_ENDPOINT, soapEndpoint);
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_TRANSPO RT_PROTOCOL, ServiceClientFactoryProperties.DSC_SOAP_PROTOCOL);
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_SERVER_ TYPE, serverType);
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENT IAL_USERNAME, userID);
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_CREDENT IAL_PASSWORD, userPassword);
ServiceClientFactory myFactory = ServiceClientFactory.createInstance(connectionProps);
It seems that the connection is done with the default LiveCycle user, like when we use :
ServiceClientFactory myFactory = ServiceClientFactory.createInstance();
Is there a way to force the connection with a specific user inside a DSC Component ?
Kind regards,
Thomas
After some investigational debugging in the server, I found the error.
The DSC was indeed using the correct credentials.
The new problem is that I have this exception :
java.lang.ClassNotFoundException: [ACTIVE] ExecuteThread: '0' for queue: 'weblogic.kernel.Default (self-tuning)'Class name com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapAxisDispatcher from package com.adobe.idp.dsc.provider.impl.soap.axis.sdk not found.
Do I need to "import" this class manually in my component ? If yes, how ?
Kind Regards,
Thomas
After all I found a solution, I used EJB instead of SOAP for connection, so my code looks like this
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_DEFAULT _EJB_ENDPOINT, ejbEndpoint);
connectionProps.setProperty(ServiceClientFactoryProperties.DSC_TRANSPO RT_PROTOCOL, ServiceClientFactoryProperties.DSC_EJB_PROTOCOL);
Hope this helps !
Regards,
Thomas
North America
Asia Pacific
