Folio Builder preview freezes
Aug 12, 2011 2:06 AM
I've searched the forum for a similar subject, but haven't found one.
The Folio Builder Preview button used to work.
I now have added several articles, and it fails to fire up the desktop viewer.
When I click on Preview, it launches a windows indicating "Verifying content folio 1 on 21" (may not be exactly that in English, I've translated as I'm using the software on a french localized version of InDesign CS5.5) and stays forever that way.
I have uninstalled and reinstalled the DPS tools several times.
I have updated every article separatly, everything went fine (and folios' been created).
If it helps, the temporary files in the first article are created then removed - I guess this indicates the first article has been processed - but it does not create the temporary files for the second article.
Next step will be to delete all articles and import them again. But did I mention that Importing several articles doesn't work either? Same problem: progress window sits & waits forever...
Help sought!
Fred
    Aug 12, 2011 2:27 AM   in reply to fredericbotton
    i want to chime in on you, i encounter the same problem on huge folios with
    more than a few articles.
    it seems tto stop on folio 1 of X but eventually get it working. or
    sometimes not (or i am not patient enough)
    I think the folio builder downloads the folio from the server because it
    uses the server version, not my local version.
    and that takes forever.
    i copied some articles into a new folio to solve the problem and wait not so
    long.
    —Johannes
    (mobil gesendet)
  • Bob Bringhurst
    May 29, 2007
    Aug 12, 2011 8:53 AM   in reply to Johannes Eckert
    If preview freezes, first try deleting and re-creating the articles, as Johannes suggested. If that doesn't work, the temp .folio files used for previewing may have become corrupt. On a Mac, you can delete the DMP folder at this location:
    [Username] > Library > Preferences > StageManager.[#######] > Local Store > dmp
    If you delete this folder, your temp .folio files will be re-created the next time you preview.
