I just made a flash movie and I would like it to stream and save it as mov format. But I got an error instead. It mention I can go to the publishing settings but I don't see the option it listed to fix the problems. Any ideas? Thanks.
that's a warning, not an error.
to remove, click file/publish settings/flash/actionscript 3.0 settings/library path/default linkage and select "merged into code".
Thank you so much! It worked.
you're welcome.
