Style Warning when using a custom theme
Aug 17, 2011 9:32 AM
I'm have a Flex application project and a Custom Flex Theme project. I'm with latest Flash Builder and with latest Flex SDK
I am using -theme "path-to-.swc" to apply my custom theme to my app
I get various warnings like this:
El estilo 'backgroundAlpha' sólo es compatible con el tipo 'mx.controls.ToolTip' con tema(s) 'halo, spark, mobile'.
translated:
The style "backgroundAlpha" is only compatible with the type 'mx.controls.ToolTip' with theme(s) 'halo, spark, mobile'.
If I remove all backgroundAlpha from my theme default.css, it continues to show me the warning
Moreover backgroundAlpha is used in spark theme. Example:
Application
    backgroundColor: #FFFFFF;
    skinClass: ClassReference("spark.skins.spark.ApplicationSkin");
So, it's a bug in Flash Builder or I'm doing something wrong?
Carlos Rovira
    Aug 19, 2011 4:02 AM   in reply to Carlos_Rovira
    Hi Carlos,
    You might be using the 'background Alpah' property with your 'mx.controls.ToolTip' somewhere in your mxml.
    Delete it from there and that should work
    Cheers,
    Guriya
    Sep 5, 2011 5:53 AM   in reply to Guriya Kalyani
    Hi Carlos,
    When applying the themes via the compiler option, use -theme+=<path to the theme.swc>
    instead of -theme=<>
    That should get rid of the warnings. Thanks.
