JoeriADAM
Custom properties example
Aug 18, 2011 5:27 AM
is it possible to provide us with an example on how to use the new 'Custom Properties' functionality in Drive 3.0 ?
We are unable to find an example in the samples, and the documentation does not help us to get started.
We need to be able to show (and edit) custom metadata from our database. Any help on which handlers we should use, example on how to make the data visible in the custom properties UI would be very helpful.
Thanks in advance.
    Aug 21, 2011 8:38 AM   in reply to JoeriADAM
         To use custom properties feature, there are four capabilities specific for it, they are Capabilities.READ_METADATA, WRITE_METADATA, CREATE_METADATA and REMOVE_METADATA,  enabling READ_METADATA will leads to a new context menu item named "custom properties" in Bridge, clicking it will pop-up custom properies UI, through it,you can one asset's version properties contained in the receipes you connector provided, the properies are name-values pairs, to create, remove and modify the properties, you should implement AddPropertiesHandler, RemovePropertie/Handle and a optional GetPropertyDefinitionHandler and open other there capabilities, currently only string, boolean and integer properties are supported, multi-value properites should be provided through java List class instances.
          Custom properties can not only be viewed through custom properties UI but also through inspector in Bridge, you can enable in in Bridge preferences.
          anything unclear, please post here
    Aug 22, 2011 7:14 AM   in reply to JoeriADAM
    Yes. in your case. I think READ_METADATA and WRITE_METADATA is enough.
    You have to implement AddPropertiesHandler since this handler is reponsible for creating properties and writing properites.
    You need to use updateReceipe.createVersionPropertyData when the dataType is "VERSION_PROPERTY", not "ASSET_PROPERTY", none-versioning asset's properties, like folder's properties, is not supported, only applicable for file's properties
