Here is the link to Adobe's help topic on the subject:
http://help.adobe.com/en_US/FrameMaker/8.0/help.html?content=Chap10-Color_10.html
Look at the graphic above the caption that reads, "You can also use overprinting to combine two colors for special effects."
That is the effect I am trying to get. How?
I placed one object on top of the other.
In Object Properties, I selected Overprint for both graphics. Nothing happened.
In Photoshop, I think this is called a Screen or Multiply blend mode. But it's accomplished with layers, which FrameMaker doesn't have.
Thanks!
Jason
The link doesn't work. The forum seems to be corrupting it by invisibly inserting
forums.adobe.com/
and appending
&urlhash=kHOY&_t=tracking_anet
In any event, once found, the FM8 Help page does seem to imply that FM8 has transparency/opacity for Frame graphics.
I lately attempted to see if FM9 supported opacity for imported EPS objects with no luck, and someone else was asking in that same thread for opacity in Frame graphics.
I'll be surprised and delighted if FM has transparency support for anything beyond line art.
The images I am working with are line art. That is, they are native FrameMaker drawings with fills applied.
Transparency in unfilled line art generally works for Frame Graphics, vector EPS, probably vector PDF, possibly SVG, and who-knows for vector WMF. The EPS or PDF preview image is always opaque - you have rto check the PDF output to verify.
That is claimed to work in 8.0 and later, but nobody seems to know how. That same example is in Help 10.0, with no clues as to how the Help author thought such a thing would be created in or imported into Frame.
Poking around in my copy of FM9, I see no tools for setting the opacity of a filled object - a crucial control for overlaid objects. (Actually, I can't even set a fill in my copy of 9.0p255. The fill button does nothing. I can only control the border.)
