I was trying out the code sample provided in the sdk help on converting the word document into pdf. I could not get the code to work and was prompted with the following exception:
java.lang.IllegalStateException
at com.adobe.idp.dsc.clientsdk.ServiceClientFactory$1.handleThrowable(Se rviceClientFactory.java:67)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:2 20)
at com.adobe.livecycle.generatepdf.client.GeneratePdfServiceClient.creat ePDF(GeneratePdfServiceClient.java:172)
at testadobeapp.Main.main(Main.java:49)
Caused by: java.lang.NoClassDefFoundError: javax/ejb/EJBException
at com.adobe.idp.dsc.clientsdk.ServiceClientFactory.evaluateMessageDispa tcher(ServiceClientFactory.java:558)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:2 15)
... 2 more
My code is as follows:
package testadobeapp;
import java.util.*;
import com.adobe.idp.Document;
import com.adobe.idp.dsc.clientsdk.ServiceClientFactory;
import com.adobe.livecycle.generatepdf.client.*;
import java.io.File;
import java.io.FileInputStream;
* @author Administrator
public class Main {
* @param args the command line arguments
public static void main(String[] args) {
Properties ConnectionProps = new Properties();
ConnectionProps.setProperty("DSC_DEFAULT_EJB_ENDPOINT", "t3://20.2.150.64:8001");
ConnectionProps.setProperty("DSC_TRANSPORT_PROTOCOL", "EJB");
ConnectionProps.setProperty("DSC_SERVER_TYPE", "Weblogic");
ConnectionProps.setProperty("DSC_CREDENTIAL_USERNAME", "username");
ConnectionProps.setProperty("DSC_CREDENTIAL_PASSWORD", "password");
ServiceClientFactory factory = ServiceClientFactory.createInstance(ConnectionProps);
try {
String inputFilename = "c:\\test.docx";
FileInputStream fileInputStream = new FileInputStream(inputFilename);
Document inDoc = new Document(fileInputStream);
String adobePDFSettings = "Standard";
String securitySettings = "No Security";
String fileTypeSettings = "Standard";
CreatePDFResult result = new CreatePDFResult();
result = new GeneratePdfServiceClient(factory).createPDF(inDoc, inputFilename, fileTypeSettings, adobePDFSettings, securitySettings, null, null);
Document createdDocument = result.getCreatedDocument();
createdDocument.copyToFile((new File("C:\\test.pdf")));
} catch (Exception e) {
e.printStackTrace();
Am I missing something here? Thanks in advance.
Based on your exception:
Looks like the ServiceClient cannot locate your instnace of LC ES. This exception is not related to a PDFG operation -- if it was - you would have an exception something like:
ALC-PDG-80023-000: com.adobe.livecycle.generatepdf.client.ConversionException:
Error message from the primary converter:
ALC-PDG-080-023-Acrobat_PATH environment variable either not set or is invalid. Please set this variable to point to Acrobat.exe in Acrobat version 9 with update 1. Acrobat_PATH should be set to <Acrobat_Home>\Acrobat 9.0\Acrobat\Acrobat.exe. Here <Acrobat_Home> is the parent folder where the Acrobat is installed.
Error message from the fallback converter:
ALC-PDG-011-030-Submitted OpenOffice Document could not be converted to PDF. Either OpenOffice is not installed on this system or environment variable OpenOffice_PATH is not set
I would try another service like the Encryption service and see if you can encrypt a PDF with a password. This will rule out a problem with your client being able to invoke your instance of the server.
North America
Asia Pacific
