Some .png Files Won't Open, Others Will
Aug 26, 2011 1:17 PM
Okay, so this is a silly question/problem, but it's still one I would like to resolve. I am trying to edit some Minecraft .png files so that I can fix a mod. However, when I ask the computer to open it in Photoshop (I have 6), it opens Photoshop but then it just sits there as if it's finished. No message, nothing of that sort. It just... does nothing at all.
Any suggestion on how I could fix this?
Thank you so much for any help!!
~PheonRen
    Aug 26, 2011 2:37 PM   in reply to Pheonren
    Welcome to the forum.
    What is different about the PNG files that will open, and the ones that will not?
    Though more often used for AV files, MediaInfo does a pretty good job of pulling out all the specs. to most still image file formats. Have not tried it with PNG's, so do not know how well it will work. Will test, and report back. If it does handle them, it might point out differences, and it's free.
    Also, will the problem PNG files open in other programs, like IrfanView? Usually, if a file will not open in PS, one does get an error message, but you did not.
    [Edit] Yes, PNG files do open in MediaInfo, and look at the details in Tree View.
  • Noel Carboni
    Dec 23, 2006
    Aug 26, 2011 7:00 PM   in reply to Pheonren
    If you're willing, post one of the PNGs that won't open here and I (or others) can let you know if a newer version of Photoshop can deal properly with the file.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 27, 2011 6:49 AM   in reply to Pheonren
    Use the little camera icon just above where you type to upload an image file.
    Why are you trying to load a plug-in?  Photoshop 6.0 really should handle PNG files right out of the box.  I suspect there's could be something wrong with the file, and we can try to verify that with the file you post here.
    -Noel
  • JJMack
    Jan 9, 2006
    Aug 27, 2011 7:21 AM   in reply to Pheonren
    Is that one the does not open for you in Photoshop???  Are you using Photoshop version 6 which is very old or Photoshop Elements 6 which is just old?
    Aug 27, 2011 7:23 AM   in reply to Pheonren
    Part of the problem may be that your file has two file extensions and even
    though they are both png, it's usually a good idea to only use periods on the
    the file extension and no where else in the file name.
    Photoshop thinks any periods stand for file extensions and may get confused
    if it sees more than one period.
    MTSTUNER
  • Noel Carboni
    Dec 23, 2006
    Aug 27, 2011 7:27 AM   in reply to Pheonren
    That image opened right up in my copy of Photoshop 6.0, so it's not a fundamental incompatibility of Photoshop 6.0.
    Something to look at...  You say you don't get any error message, but Photoshop doesn't display the image...  Do the panels change to where it looks like the image is being opened but just not shown to you (e.g., choose Window - Navigator, then try to open the image).
    -Noel
    I was able to open the file in photoshop 6 without any problem.
    Have you tried using File>Open As and choosing png and also is your
    photoshop 6 updated to 6.01?
    MTSTUNER
  • JJMack
    Jan 9, 2006
    Aug 27, 2011 7:33 AM   in reply to MTSTUNER
    That is not a problem you can have many periods in a file name   like  "John Doe Jr. C.E.O. Adobe Inc..png" should not be a problem its a proper file name just not a normal file name.
  • JJMack
    Jan 9, 2006
    Aug 27, 2011 7:48 AM   in reply to Noel Carboni
    Also post a list of the plug-ins you have inatslled in the plug-in root and file format directories so we can see what is there
    Directory of C:\Program Files\Adobe\Adobe Photoshop CS2\Plug-Ins
    08/27/2011  10:40 AM    <DIR>          .
    08/27/2011  10:40 AM    <DIR>          ..
    06/06/2007  09:31 PM    <DIR>          Adobe ImageReady Only
    06/06/2007  09:31 PM    <DIR>          Adobe Photoshop Only
    06/06/2007  09:31 PM    <DIR>          Digimarc
    08/14/2011  02:33 PM    <DIR>          Displacement Maps
    06/06/2007  09:31 PM    <DIR>          Effects
    06/06/2007  10:16 PM    <DIR>          Extensions
    06/06/2007  09:31 PM    <DIR>          File Formats
    06/06/2007  09:31 PM    <DIR>          Filters
    06/06/2007  09:31 PM    <DIR>          Import-Export
    08/27/2011  10:40 AM                 0 list.txt
    04/03/2010  06:29 PM           618,496 NeatImage.8bf
    06/06/2007  09:31 PM    <DIR>          Parser
                   2 File(s)        618,496 bytes
                  12 Dir(s)  11,098,345,472 bytes free
    Directory of C:\Program Files\Adobe\Adobe Photoshop CS2\Plug-Ins\File Formats
    08/27/2011  10:41 AM    <DIR>          .
    08/27/2011  10:41 AM    <DIR>          ..
    03/22/2005  02:20 AM            37,376 BMP.8BI
    03/22/2005  02:21 AM            14,848 FilmStrip.8BI
    03/22/2005  02:23 AM            20,992 PCX.8BI
    03/22/2005  02:23 AM           139,264 Photo CD.8BI
    03/22/2005  02:24 AM            14,848 Pixar.8BI
    03/22/2005  02:25 AM            26,112 Targa.8BI
                   7 File(s)        253,440 bytes
                   2 Dir(s)  11,098,300,416 bytes free
  • Noel Carboni
    Dec 23, 2006
    Aug 27, 2011 9:24 AM   in reply to Pheonren
    Pheonren wrote:
    On the pick list for "open as", png is not an option.
    It should be.  Something you've installed or done to Photoshop must be blocking it.
    When you tried to install that PNG plug-in, did you remove it again?
    Do you have the Adobe Png.8bi plug-in on your system in one of these two places (the second one is where it goes on 64 bit systems)?
    C:\Program Files\Adobe\Photoshop 6.0\Plug-Ins\Adobe Photoshop Only\File Formats\Png.8bi
    C:\Program Files (x86)\Adobe\Photoshop 6.0\Plug-Ins\Adobe Photoshop Only\File Formats\Png.8bi
    -Noel
  • JJMack
    Jan 9, 2006
    Aug 27, 2011 9:39 AM   in reply to Pheonren
    Pheonren wrote:
    Here are my plugin folders. Are there any you would like a list of what's inside the folders?
    Parser
    Import-Export
    Filters
    File Formats
    Effects
    Displacement Maps
    Digimarc
    I don't know how you got that list that you displayed.
    The good all old  fasion DOS command Dir. If  you can not do that use windows file explore and capture two  screen showing the files inside the root plugin directory and inside the file format directory all you showed are directories no plug-ins use the details view please.
  • Noel Carboni
    Dec 23, 2006
    Assuming by "it" you're talking about the PNG plug-in...  Is this plug-in you're trying to put in that folder the one from Adobe for Photoshop 6.0?
    Do you have permissions to write into that folder?  What OS are you running?
    I think rather than messing around with individual files I'd suggest reinstalling Photoshop.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 27, 2011 9:42 AM   in reply to Pheonren
    Pheonren wrote:
    Maybe it doesn't work for mine. The folder it is in says "Photoshop 7" although it stated it worked as far back as 5.5.
    You seem to have some confusion over versions...
    You're working with Photoshop 6.0, right?  Are you sure?  What does Help - About in Photoshop say.
    The folders for Photoshop 6.0 are as I listed above, exactly, they do not contain the numeral 7.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 27, 2011 10:29 AM   in reply to Pheonren
    I can't say why your SuperPNG plug-in won't work.  It looks like you have it in the right place.  You HAVE closed and restarted Photoshop after putting it there, right?
    Is there anything special about the PNG files you're editing that makes you think you need something more than the standard Adobe plug-in?
    If you're unwilling to reinstall Photoshop to recover the Adobe Png.8bi that has been deleted, I don't know what else to advise.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 27, 2011 10:45 AM   in reply to Pheonren
    For what it's worth, the Photoshop installation doesn't wipe out previously installed plug-ins, and doesn't reset preferences.  It may not be as traumatic as you think.
    Best of luck with Irene.  I hope it's losing strength.
    -Noel
