TLF text direction.
Aug 28, 2011 12:50 PM
Hello there!!
When I create a TLF text area that is editable at runtime (which means that it can get a user input at runtime) I set the text direction to the 'right-to-left' definition in both the 'container and flow' and the 'paragraph' sections and set the language for Arabic or Hebrew at the 'locale' setting. I also set the text alignment to the 'align to start' mode.
Now at runtime there's a stange thing. When I try to click with the mouse cursor on the editable TLF text-box, it's not displaying the text icon cursor and don't allow me to insert text inside. But when I move my mouse cursor over the right side of the editable TLF text box, it change his appearance to the familiar text cursor which indicate that if you click here you will be able to insert text input inside.
So my problem is how can I make it that only when I will hover over the TLF text box itself, the mouse cursor will be changed to text cursor icon and when I will hover beside its right side, it will remain at the normal cursor mode.
Thanks in advance!!
Atar.
    Aug 30, 2011 7:38 PM   in reply to atar11
    having the same problem!!!! help!!!
    more details:
    the bug happens even if the direction stay in left to right.
    just set the align to right and you will see the problem!!
    hrere code:
    var myTLFTextField:TLFTextField = new TLFTextField();
    addChild(myTLFTextField);
    myTLFTextField.x = 10;
    myTLFTextField.y = 10;
    myTLFTextField.width = 200
    myTLFTextField.height = 120;
    myTLFTextField.multiline = true;
    myTLFTextField.wordWrap = true;
    myTLFTextField.border = true;
    myTLFTextField.borderColor = 0xff0000;
    var myFormat:TextLayoutFormat = new TextLayoutFormat();
    myFormat.textIndent = 2;
    myFormat.color = 0x336633;
    myFormat.fontFamily = "Arial";
    myFormat.fontSize = 13;
    myFormat.textAlign = TextAlign.RIGHT;
    var myTextFlow:TextFlow = myTLFTextField.textFlow;
    myTextFlow.hostFormat = myFormat;
    myTextFlow.flowComposer.updateAllControllers();
    now i found a "bandage" solution:
    if the fontSize set to 13 and the height of the field to 16 it work perfect
    and if the height of the field close to fontSize it work
    but i wont a multiline textfield with something like 120px height with small font size.
    please help.
    Jun 12, 2012 10:28 PM   in reply to yon876
    if u only puplish your fla file in flash cs5 this problem will be fixed (but i cant find any thing to correct this bug in flash cs5.5 or cs6 )
    Oct 18, 2012 2:22 AM   in reply to atar11
    Hello mate,
    i'm facing the same problem, tried many suggested solutions asked many flash developers, but unfortunately nothing worked
    have you figured out the isuue and have a reliable solution?
    that would be highly appreciated
    thanks in advance
    Nov 7, 2012 3:59 AM   in reply to akram85s
    I've had this same problem. My fix is posted over here: https://github.com/alexdeefuse/TLFTextField-fix
    I tested it only on single line TLFTextFields.
    If you take a look at the fix, what I'm doing is go down the display list of the TLFTextField and correct the position of the SimpleButton inside there. (the button is responsible for the user input and TLF's extend DisplayObjectContainers).
    Hope it helps!
    Regards, Alex Ghiu
    Nov 7, 2012 4:32 AM   in reply to Alex Ghiu
    Thank you so much,
    that was absolutely helping
    much appreciated
    btw i have solved it in another way (moving alignment rulers manually)
    which worked good for single-line text
    and here is how i fixed it (my stupid way)
    Regards,
    Akram Alsmadi
    Sep 16, 2013 12:47 PM   in reply to akram85s
    Has this been solved by Adobe yet? This is incredibly frustrating.
    I have TLF text that is being named using AS, but since the nav has different line lengths, they don't stay right aligned and end up all over the place. It seems to me this is just a bug in Adobe's coding, but I don't understand why it hasn't been fixed after so much time.
    Do I have to completely redesign my FLA just to accomodate for this error?
