I'm not sure if you are aware, but it is currently very difficult to test spark Application components using FlexUnit and the UIImpersonator. An application component can't simply be added to UIImpersonator with addChild; there is already an existing Application for the test environment. What you have to do instead is create and add a SWFLoader and then use that to load an instance of the Application to test. The workaround is not very difficult, but having a mention of this issue in the documentation somewhere would have been helpful. Better yet perhaps add a function to UIImpersonator that takes care of the extra steps involved in testing an Application. What do you think?
Its okay that it is based on flex 3 components, it would just need to be compiled with the Flex 4 SDK or you need to wait until the next release of FlexUnit to make it cleaner.
In the 4.1 release we basically look for global clues as to whether it is 4.x or 3.x as it is unfortunately difficult (as you have seen) to handle them both together.
Mike
So addElement() is not usable in the current release version? My project is compiled with flex 4.5 so I don;t think thats the issue here.
Also, even if addElement did work, it would still be better to use the SWFLoader method, otherwise the applicationComplete event would never get dispatched.
Yes, it is completely usable.
How it works is that FlexUnit tries to see if there is a mx.core.Container linked into your project. If there is, it uses that as the basis for the UIImpersonator. If there isn't one, then it uses spark.components.Group.
It does this because it is possible to compile in Flex 4.x with or without the MX components.
If your project has both, MX and Spark, then you can continue to use addChild() and you should be able to add either spark or mx components to the display list with 4.1. If your project is spark only then you need to use addElement(). We are just trying to make this cleaner for future releases but it does work now.
As far as the loader, etc. I certainly understand why you are doing that and if it works then by all means its a good solution. FlexUnit was never intended though to be able to test full applications, so things like applicationComplete were never on our radar. So, for now, you will need to continue your work around to have that functionality or, you could always manually dispatch it (myApp.dispatchEvent( new Event("applicationComplete") ) ) at the appropriate time.
HTH,
Mike
North America
Asia Pacific
