Ok, after 10 days with out FW CS5 on my new Lion installment. I finally cracked some kind of bug where FW would freeze just after loading and the last text in the CS5 logo was tabs and then the processor would go up to around 81% and just freeze.
Apple and Adobe, both blame each other and none could give an answer, but to re-install everything, which i just had done. (Man the big dudes are lost sometimes!)
"My" problem turned, that I seemlessly had a corrupt file in my ~/Library/Preferences/
But i couldnt figure out which one it was.
I ran a Terminal plutil -s *.plist and no errors showed up.
The solution turned out to be:
Deleted the entire macromedia folder in the ~/Library/Preferences/ folder and now its working.
macromedia is the name of the old FW creators before Adobe took over.
So i am guessing there is some kind of error, but who can tell. I cant, adobe cant and apple cant.
Well hope this helps somebody!
Hi guys, glad it helped.
Just for you info.
For each time you reboot, you will have to manually delete the folder /macromedia in the ~/Library/Preferences/
before starting FW. Cause the macromedia folder is created each time FlashPlayer is used, which i guess it is almost all the time you browse or use similar adobe libraries like shockwave, airplay etc.
Abobe i kinda guess that this is something you should work out with Apple.
Atb Sofus
I think I might have narrowed it down.
In the macromedia/#Security/FlashPlayerTrust folder a file is created by the flashfirebug extension when my Firefox browser is opened. The file flashfirebug.cfg is created.
Deleting this file fixes both the extension manager and fireworks launch problem.
Removing the extension from Firefox and deleting the cfg file solved my problem for good.
Hope this helps.
Mike
Thank you so much for this post! I was having this exact same issue and was at the brink of reverting back to Snow Leopard. As soon as I deleted that Macromedia folder, boom... Fireworks opened for the first time in 4 months!
However, has anyone noticed that as soon as you open Fireworks, that Macromedia folder gets recreated?? At least it did for me.
So how to I make it stay gone? Not a huge deal, but sure is a pain to have to go and delete it every time I want to run the program.
Anyway, thank you again for this answer.
I've tried everything mentioned above, but I'm still getting this:
"Fireworks can not run. An internal error occurred."
It happens when the status message in the Fireworks startup panel reads "Initializing Textures." I've searched my whole computer for "textures" hoping to be able to temporarily disable something, but I don't see anything like that in any Fireworks CS5 folders.
Any further suggestions?
Hi Folks!
Its because the macromedia folder is recreated each time flash is used somehow.
I made an Automator App that
1) Locates the ~/Library/Preferences/Macromedia
2) Moves the Macromedia Folder to the Trash
3) Runs Adobe Fireworks CS 4
So all I need to do is click this Automator App instead of the Fireworks App in my Dock, and then I am sure it will start.
(I Know that this is not a 100% cool in the end fix, but seems like Adobe are ignoring this error after several of attempts of direct action to tell them.)
Here is how to build your own automator app that does these three steps for you.
My finder is in danish, but I translated it in red text for you. Guess its easy to figure out:
Remember!!! If you are running Adobe Fireworks CS5 then choose that in step 3 instead :-)
Per my experience, the problems is FlashFireBug plugin for Firefox to be exact. And it seems this plugin creates a file within the Macromedia folder. So you first just delete the Macromedia, kill your FlashFireBug plugin, then it should work without having to keep deleting the Macromedia folder.
Fantastic! Thank you so much to both guys who found and pin pointed this issue!
This also works for CS6 too. Cant believe Adobe havn't already put something in place for this knowing that a 3rd party extension is causing one of its products to not even launch!
i salute you!!! Saved me hours and also major grief from not being able to open some layered PNGS.
Hello All,
We're the authors of FlashFirebug. We thought this bug was ironed out quite some time ago. But perhaps not. If someone can answer the questions below, that would be quite helpful:
1. Does this problem still occur with FlashFirebug 4.54?
2. Does this problem happen with only MAC or also on Windows?
3. If problem does still occur with 4.54, can you search for ffbug.cfg in your home folder and paste the contents of the file here?
4. Delete the file ffbug.cfg, does the CS5 problem go away? (make sure you don't restart Firefox after deleting it, because it will recreate it).
Thanks! Looking forward to iron out this annoying bug. But need your help to do so ![]()
North America
Asia Pacific
