Hoping there is a SQL guru out there that can help me with this ![]()
I have two tables that I want to pull data from and display a report, based on a particular date range, for this example let's say 08/01/2011 to 08/31/2011
In one table there would be an affiliate ID - AFF_UID and also the date and a counter for that date, IMP_COUNTER , now there may only be a few records not every day might be covered, say
TABLE IMP
date,aff_uid,imp_counter
08/01/2011,999,2000
08/02/2011,999,2050
08/20/2011,999,2030
etc
I then have another date, similar set up only there are multiple records in here for a single day, again not all days covered, I would need to total up each row for each day to get a count. So it might be:
TABLE LEAD
date,aff_uid
08/01/2011,999
08/01/2011,999
08/01/2011,999
08/01/2011,999
08/12/2011,999
So we have different dates covered, sometimes the same date, I need the counter from the first table, and from the second table I need to add them up for a total, and then display any date that has a value and put both counter and lead count together
Result from above
date,imp total,lead total
08/01/2011,2000,4
08/02/2011,2050,0
08/12,2011,0,1
08/20/2011,2030,0
I am sure there must be a SQL command that can gel all of this together with some grouping? Last thing I need is a ton of SQL statements in a loop!
My alternative is to add a counter to the IMP table for each lead, so every time I update the lead table with a record, I will also update the counter, but that's unncessary storage of data I already have an an extra update statement that I might be able to do without, but maybe it would make generating reports faster, just pulling to counters with no 'addition' required.
Appreciate any feedback
Mark
select imp.date
, imp.aff_uid
, count(lead.aff_uid)
, counter
from imp join lead on imp.date = lead.date and imp.aff_uid = lead.aff_uid
where imp.date >= somedate
and imp.date < someotherdate
group by imp.date, imp.aff_uid
This is pretty basic stuff. Since you had to ask, I've heard good things about the book, Teach Yourself SQL in 10 Minutes by Ben Forta
I put in the correct field names and tried it out, but unfortunately it's throwing an error
[Macromedia][SQLServer JDBC Driver][SQLServer]The multi-part identifier "imppressions.imp_date" could not be bound.
Here's what I have
SELECT
imp_date,
imp_aff_uid,
imp_counter,
count(leads.lead_aff_uid)
FROM impressions JOIN leads ON impressions.imp_date = leads.lead_date and
imp_aff_uid = leads.lead_aff_uid
WHERE imppressions.imp_date BETWEEN #createODBCdate(form_from)# AND
#createODBCdate(form_to)#
GROUP BY impressions.imp_date,impressions.imp_aff_uid
I also need to sort by a particular specified aff_UID, guess I can add that into the WHERE when done
I added it into the group, but it doesn't work, it gives no results for the LEADS, even though there is a record in there that should show, and only lists one record in the IMPRESSIONS table, when there are two, one for the 09/01 and one for 09/02
SELECT
imp_date,
imp_aff_uid,
imp_counter,
WHERE impressions.imp_date BETWEEN #createODBCdate(form_from)# AND
GROUP BY impressions.imp_date,impressions.imp_aff_uid,impressions.imp_counter
CFDUMP showed this
SELECT imp_date, imp_aff_uid, imp_counter, count(leads.lead_aff_uid) FROM impressions JOIN leads ON impressions.imp_date = leads.lead_date and imp_aff_uid = leads.lead_aff_uid WHERE impressions.imp_date BETWEEN {d '2011-08-01'} AND {d '2011-09-30'} GROUP BY impressions.imp_date,impressions.imp_aff_uid,impressions.imp_counter
When I expect to get data and don't, I try to isolate the cause by either removing constraints one by one, or removing them all and putting them back one by one.
In this case, I'd start by taking away the where clause. If I got results, I'd put the dates back one at a time to see which one caused the problem.
If I didn't get results by taking away the where clause, I'd start looking at the two fields used in the join.
I'm at a bit of a loss with this, I pulled the whole WHERE statement out, and I also tried playing with teh GROUP varaibles but that just caused it to throw errors.
I double checked the data, and tweaked it to make sure I was not going mad. I have two records in IMPRESSIONS, 09/01 and 09/02 and two in LEADS, 09/03 and 09/04 , it displays no leads at all in this state, now if I change the dates in LEADS to match the dates in IMPRESSIONS, I get two records return from the IMPRESSIONS table.. very strange
Putting it back as it was a CFDUMP is giving this
SELECT imp_date, imp_aff_uid, imp_counter, count(leads.lead_aff_uid) FROM impressions JOIN leads ON impressions.imp_date = leads.lead_date and imp_aff_uid = leads.lead_aff_uid WHERE impressions.imp_date BETWEEN {d '2011-01-01'} AND {d '2011-09-08'} GROUP BY impressions.imp_date,impressions.imp_aff_uid,impressions.imp_counter
And this gives no records instead of the four ![]()
I played a little more after posting this and found that what is happening is that if there are no records in the IMPRESSIONS table which have the same date as data that should be displayed in the LEADS table, then the leads data will not display for that date, so if I have a record in LEADS for 09/01 and I then add a record in IMPRESSIONS for 09/01 both display, on one row, but if I take out the data in IMPRESSIONS, then the data in LEADS does not display either
Mark
Let me see if I understand your requirements, please correct the following statements if they are wrong:
1. You wish to query for a given date range defined by form_from and form_to variables.
2. You wish to include every row in the impressions table that matches the date range criteria.
3. You wish to include the count of matching rows from the leads table for each row from the impressions table based on matching aff_uid and date.
You might try something like the query below. This uses a subquery to calculate the count from the leads table based on the aff_uid and date from the impressions row. Note that I have included the date parameters in CFQUERYPARAM tags.
SELECT
I.imp_date
, I.imp_aff_uid
, I.imp_counter
SELECT COUNT(*)
FROM leads AS L
WHERE L.aff_uid = I.imp_aff_uid
AND L.lead_date = I.imp_date
) AS lead_total
FROM impressions AS I
WHERE I.imp_date BETWEEN <cfqueryparam value="#form_from#" cfsqltype="cf_sql_timestamp"> AND <cfqueryparam value="#form_to#" cfsqltype="cf_sql_timestamp">
ORDER BY I.imp_date, I.imp_aff_uid;
You might also consider posting your question to a database specific form.
Do the ID and date field values in the LEADS table exactly match the related values in the IMPRESSIONS table?
In order to assist you further it would be useful to have:
1. The creation scripts for your tables.
2. A sample of data for each table.
3. The desired resultsest based on the sample data.
4. The database server you are using: vendor and version.
Yes, the IMP_AFF_UID and LEAD_AFF_UID from IMPRESSIONS and LEAD table respectively are related back to the users UID
I created the tables manually, I guess I could create a script from the SQL management tool if needed?
this is all I have in the test
IMPRESSIONS table
imp_aff_uid,imp_date,imp_counter
525503,9/1/2011,100
525503,9/3/2011,200
LEADS table
lead_aff_uid,lead_date (also have some other unrelated data in here for this report)
525503,9/3/2011
525503,9/7/2011
525504,9/7/2011
525504,9/7/2011
So in theory I should get:
09/01/2011,100,0
09/03/2011,200,1
09/07/2011,0,3
Mark
umm. I thought there used to be a place to attach files...
Here's a creation script for the two tables (indexes are not in place yet)
USE [__a_cb]
GO
/****** Object: Table [dbo].[impressions] Script Date: 09/12/2011 19:48:17 ******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE TABLE [dbo].[impressions](
[imp_uid] [int] IDENTITY(1,1) NOT NULL,
[imp_aff_uid] [int] NOT NULL,
[imp_date] [smalldatetime] NULL,
[imp_counter] [int] NULL CONSTRAINT [DF_impressions_imp_counter] DEFAULT ((0)),
CONSTRAINT [PK_impressions] PRIMARY KEY CLUSTERED
[imp_uid] ASC
)WITH (PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY = OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY]
) ON [PRIMARY]
GO
/****** Object: Table [dbo].[leads] Script Date: 09/12/2011 19:48:20 ******/
SET ANSI_NULLS ON
GO
GO
CREATE TABLE [dbo].[leads](
[lead_uid] [int] IDENTITY(1,1) NOT NULL,
[lead_aff_uid] [int] NULL,
[lead_aff_master_uid] [int] NULL,
[lead_offer_uid] [int] NULL,
[lead_aff_percentage] [tinyint] NULL,
[lead_aff_payment] [smallmoney] NULL,
[lead_advertiser_payment] [smallmoney] NULL,
[lead_date] [smalldatetime] NULL,
[lead_pcode_uid] [int] NULL,
CONSTRAINT [PK_leads] PRIMARY KEY CLUSTERED
[lead_uid] ASC
) ON [PRIMARY]
GO
So based on your sample result set I need to assume that not every record will have a row in the IMPRESSIONS table..
You wish to get a resultset containing 3 columns:
1. An uid from IMPRESSIONS (or LEADS if there is no match in the IMPRESSIONS table).
2. A date from IMPRESSIONS (or LEADS if there is no match in the IMPRESSIONS table).
3. The count of records in the LEADS table that math the uid and date.
Is this correct? It contradicts the assumptions I stated on Sept 9 where I assumed that all records in the results would have a record in the IMPRESSIONS table, to quote "You wish to include every row in the impressions table that matches the date range criteria."
sorry, that is correct, there isa possibilty that there would be a date missing in either of the tables, so on a particular date there might be a record for IMPRESSIONS, but not LEADS, or vice versa, there could also be no records on a particular date.
So somehow I have to combine the data and report it all based on the dates that are available with some date in one or both tables
Mark
Take the date portion out of the join. It becomes this:
FROM impressions JOIN leads ON imp_aff_uid = leads.lead_aff_uid
Then, in the where clause do something like this
where (impressions.date >= something and impressions.date < something)
or (leads.date >= something and leads.date < something)
tried it, but unfortunately get the same results as bob, just the two records from the IMPRESSIONS table. Here's what I used
SELECT
imp_date,
imp_aff_uid,
imp_counter,
WHERE impressions.imp_date BETWEEN #createODBCdate(form_from)# AND #createODBCdate
(form_to)# OR leads.lead_date BETWEEN #createODBCdate(form_from)# AND
Seems like what you need is a FULL OUTER JOIN. But I do not think they are supported in MySQL. If not, you could simulate it using a UNION.
The first query should grab all impressions, with or without matching leads. The second should retrieve only leads without matching impression records. In other words, dates not already included in the first query. Something like
SELECT i.imp_date, i.imp_counter, COUNT(l.lead_aff_uid) AS leadCount
FROM impressions i LEFT JOIN leads l
ON i.imp_aff_uid = l.lead_aff_uid
AND i.imp_date = l.lead_date
WHERE i.imp_date BETWEEN ...{your filters} ...
GROUP BY i.imp_date, i.imp_counter
UNION ALL
SELECT l.lead_date, 0 AS imp_counter, COUNT(l.lead_aff_uid) AS leadCount
FROM leads l LEFT JOIN impressions i
WHERE l.lead_date BETWEEN ...{your filters} ...
AND i.imp_aff_uid IS NULL
GROUP BY l.lead_date
The result should be:
>> 09/01/2011,100,0
>> 09/03/2011,200,1
>> 09/07/2011,0,3
However you would not get those totals as long you are including the "uid" column in the SELECT list.
ACS LLC,
Below is a sample query that may work for you. It uses a full join, as previously suggested in this thread. I also suggest that you research full joins and any other keywords in the query you are not familiar with.
SELECT
COALESCE(IMP.imp_date, LEAD.lead_date) AS report_date
, COALESCE(IMP.imp_counter,0) AS imp_counter
, COALESCE(LEAD.lead_count,0) AS lead_count
FROM
SELECT
imp_date
, imp_counter
FROM impressions
WHERE imp_date BETWEEN '9/1/2011' AND '09/07/2011'
) AS IMP
FULL OUTER JOIN
SELECT
lead_date
, COUNT(*) AS lead_count
FROM leads
WHERE lead_date BETWEEN '9/1/2011' AND '09/07/2011'
GROUP BY lead_date
) AS LEAD
ON ( IMP.imp_date = LEAD.lead_date )
ORDER BY report_date;
Hey Bob, it worked!!! Fantastic
... thanks for your help. I've modified it slightly so it only pulls accounts that I want rather than the whole dbase and it works like a charm
I have to admit that I have never used COALESCE before, I see that it is tied into NULL records but I have to admit I'm not 100% sure exactly how it is working in here and how efficient this setup is, but hey it works! ![]()
I've got a few modifications to work now depending on required report, but I THINK I can handle those changes myself.. hopefully I won't be back on this thread ;-)
Thanks again
Mark
I would try removing the COALESCE and looking at how the results differ, that should help you visualize what COALESCE is doing. I encourage you to do some research and testing so that when you need to troubleshoot the query later you'll understand what each part of the SQL statement is doing.
So which one are you saying should to it??
Either. If you had tested the union, it should have worked under ms sql too. But like I said, that technique is just a poor man's full outer join.
Again, I would strongly recommend you read up on full outer joins and unions so you understand what the sql is doing and are not just using it blindly ![]()
Well I thought that I had this one up and running, but once it went into production I found that it didn't give the desired results.
I have an account that has 3 'tracking'/aff accounts, so what it's doing is giving out 3 lines for each date rather than join them together into one. The values are also incorrect, I'm still trying to figure out just where it's even getting those numbers, I manually added up the numbers in the dbase and it didn't match ![]()
Here's the command
<CFQUERY name="GetStats" DATASOURCE="#datasource#">
SELECT
, COALESCE(LEAD.lead_aff_payment,0) AS lead_aff_payment
FROM
SELECT
imp_date
, imp_counter
FROM impressions
WHERE imp_date BETWEEN #createODBCdate(form_from)# AND #createODBCdate(form_to)#
<CFIF #val(ListGetAt(form_aff_UID,1))# IS "3">
AND imp_aff_uid IN (SELECT aff_uid FROM aff WHERE aff_master_uid = #session.aff_uid#)
<CFELSEIF #val(ListGetAt(form_aff_UID,1))# IS "2">
AND imp_aff_uid = #val(ListGetAt(form_aff_UID,2))#
<CFELSE>
AND imp_aff_uid IN (SELECT aff_uid FROM aff WHERE aff_sub_uid = #val(ListGetAt(form_aff_uid,2))# AND aff_master_uid = #session.aff_uid#)
</CFIF>
) AS IMP
FULL OUTER JOIN
SELECT
lead_date, COUNT(*) AS lead_count, SUM(lead_aff_payment) AS lead_aff_payment
FROM leads
WHERE lead_date BETWEEN #createODBCdate(form_from)# AND #createODBCdate(form_to)#
AND lead_data_status = 1
AND lead_aff_uid IN (SELECT aff_uid FROM aff WHERE aff_master_uid = #session.aff_uid#)
<CFELSEIF #ListGetAt(form_aff_UID,1)# IS "2">
AND lead_aff_uid = #val(ListGetAt(form_aff_uid,2))#
<CFELSE>
AND lead_aff_uid IN (SELECT aff_uid FROM aff WHERE aff_sub_uid = #val(ListGetAt(form_aff_uid,2))# AND aff_master_uid = #session.aff_uid#)
</CFIF>
GROUP BY lead_date
) AS LEAD
</CFQUERY>
and here are the results
| TRAFFIC REPORT: 01/01/2012 - 01/21/2012 All Accounts | |||
| Date | Offers Served | Total Leads | Revenue |
| 01/19/2012 | 249 | 1 | $0.38 |
| 01/19/2012 | 11 | 1 | $0.38 |
| 01/19/2012 | 30 | 1 | $0.38 |
| 01/20/2012 | 1,006 | 7 | $2.66 |
| 01/20/2012 | 40 | 7 | $2.66 |
| 01/20/2012 | 1,090 | 7 | $2.66 |
| 01/21/2012 | 582 | 6 | $2.28 |
| 01/21/2012 | 33 | 6 | $2.28 |
| 01/21/2012 | 515 | 6 | $2.28 |
| Total | 3,556 | 42 | |
| Sub-Total | $15.96 | ||
| Referral Revenue | $0.00 | ||
| Total | $15.96
$15.96 is NOT correct, I need to find out whats going on there, but the other issue is look how it's duplicating the dates, it's one line for each account by the look of it
Can anybody help! This SQL command already got a little beyond me ![]()
Mark
After posting this I noticed something that was staring me in the face.
If you look at the report that I posted, you will see that because there are 3 accounts that it joined that it is giving the 3 results, causing it to repeat and add up the data 3 times,
The leads on the 3 days would be 1,7,6 as a total, and $0.38, $2,66 and $2.28 = total of $5.32 which would be correct.
If I could stop it repeating like that and just have the one like for all aff accounts it might resolve the issue!
Plus I need to stop full zero lines from appearing
Mark
Thought it might help to post a CFDUMP to try demonstrate where it's going wrong:
| query | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| RESULTSET |
| CACHED | false | |||||||||||||||||||||||||||||||||||||||||||||||||||||||
| EXECUTIONTIME | 0 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||
| SQL | SELECT COALESCE(IMP.imp_date, LEAD.lead_date) AS report_date , COALESCE(IMP.imp_counter,0) AS imp_counter , COALESCE(LEAD.lead_count,0) AS lead_count , COALESCE(LEAD.lead_aff_payment,0) AS lead_aff_payment FROM ( SELECT imp_date , imp_counter FROM impressions WHERE imp_date BETWEEN {d '2012-01-01'} AND {d '2012-01-21'} AND imp_aff_uid IN (SELECT aff_uid FROM aff WHERE aff_master_uid = 213261) ) AS IMP FULL OUTER JOIN ( SELECT lead_date, COUNT(*) AS lead_count, SUM(lead_aff_payment) AS lead_aff_payment FROM leads WHERE lead_date BETWEEN {d '2012-01-01'} AND {d '2012-01-21'} AND lead_data_status = 1 AND lead_aff_uid IN (SELECT aff_uid FROM aff WHERE aff_master_uid = 213261) GROUP BY lead_date ) AS LEAD ON ( IMP.imp_date = LEAD.lead_date ) ORDER BY report_date; | |||||||||||||||||||||||||||||||||||||||||||||||||||||||
North America
Asia Pacific
