I haven't used On Location for several months. I have been updatding regularly. I just did my update 2 days ago - it says On Location CS5 is up to date.
The program opens find, I choose my camera, the feed shows up in my monitor. Typically at this point, I click record and it creates a clip of whatever is in the monitor.
Now, I click record and nothing seems to happen. Feed is still live, histogram bumping, microphone input reacting, but nothing recording. no clip forming in the project space, no timeline movement. f2? same thing.
any ideas? Thanks!
win7, i7920, 12g ram, latest cs5
Mark
Thank you. I have disabled camcorder. Unfortunately it did not solve the problem. :-(
There is an option in my Monitor to view "UScreenCapture".
does the bug extend to screen sharing programs?
I am having challenges uninstalling UScreenCapture (search doesn't find it, not listed in cPanel:Programs.
If I can get it uninstalled I will test.
Thanks again,
Mark
Yes, anything that shows up as a selectable device in OL, other than a camera connected via FireWire of course, can cause this problem. Sorry, I should have been more expansive. Webcams have been by far the most common cause, but by no means the only one.
I don't know what to suggest regarding UScreenServer. I just installed it, and it shows up in Windows' Add/Remove Programs dialog. It might be sufficient to kill the process through Task Manager. If it launches automatically upon starting the computer, then you might want to disable that either through the program or through msconfig.
Uscreencapture is part of the applian video capture software. uninstalling this program makes OnLocation work correctly. So, if Uscreencapture is in your list of cameras, it may either - lead OnLocation to NOT SEE your video camera, OR, it may see the camera but freeze when you try to record.
Thank you Mr. Mapes again, for all of your help.
I am running cs5 onlocation on my macbook pro and am now having this same issue with my GL2. It used to record and now isnt. I dont see any other cameras in the dropdown but it wont let me record.
Ive tried to just use the camera as a camera and see if it would record live and it wont.
and Ive tried to record off the tape and it wont.
It worked fine for months upon months before. now nothing.
any ideals
North America
Asia Pacific
