Does anyone have a comprehensive list mapping PHP data types to those in Flash Builder, specifically so that they are understood when using the Data|Connect to PHP menu? I have worked out most of them, but I'm having trouble mapping integers larger than 32 bits and floating point numbers from PHP to Flash Builder.
For instance:
<?php
class Frame {
* @var integer
public $id;
* @var float
public $fpNum;
* @var int
public $int32Num;
* @var float
public $int64Num;
results in an Actionscript valueObject that has corresponding types of int, int, int and int. This doesn't seem right - surely a float should become a Number, and likewise with a 64-bit integer?
The only information that I've been able to find is here: http://framework.zend.com/wiki/display/ZFPROP/Zend_Amf+-+Wade+Arnold#Z end_Amf-WadeArnold-TypeMappingTable - but Flash Builder doesn't seem to behave according to the table. I know that it's possible to override the mappings, but it would be nice if Flash Builder understood how to map them properly. Any ideas?
I've also found that Flash Builder is unable to determine data types for arrays of objects, or if a type is used as a child of a returned type. In this instance, adding a dummy function to PHP to return an empty object of the 'missing' type seems to work - but really shouldn't be necessary.
Any thoughts/insights would be warmly welcomed!
I'd just about given up on this forum, so apologies for not posting my solution...
Anyway, it's a kludge, but you basically have to declare the variable as a string:
* @var string
public $int64Num;
The corresponding valueObject string can be used in functions, e.g.:
var f:Frame = value as Frame; // corresponding valueObject
var dt : Date = new Date();
dt.setTime(f.int64Num);
The solution to the second problem is to declare something in your PHP service which returns a single (i.e. non-array) version of the PHP object, e.g.:
* @return Frame
public function emptyFrame() {
return new Frame();
* @return Frame[]
public function getAllFrames() {
Hope this helps someone...
FYI, I just found a workaround for mapping double/float in PHP with Number in AS. If you change static data mappings in a target service manually, FB will convert double/float to Number automatically. Your service information can be found in YOUR_WORKSPACE/YOUR_PROJECT/.model/YOUR_PROJECT_NAME.fml.
1. Open the model file using any text editor. (I use Notepad++ because it has a nice syntax highlight feature.)
2. Find your entity notation. i.e. <entity name="Frame">....</entity>
3. You can find your property within the entity. i.e. <property name="fpNum" type="integer" required="true"/>
4. Change type from integer to double. i.e. <property name="fpNum" type="double" required="true"/>
5. Restart your FB.
Note there is a downside. Whenever you refresh/reconnect to your service, you need to change them again. Otherwise, you'll lost your data mapping. I hope this help someone.
North America
Asia Pacific
