woop11.04
Unable to change preferences for Adobe Reader 9.4.2 on Ubuntu 11.04
Sep 2, 2011 4:44 AM
I installed Adobe Reader 9 via the Ubuntu Software Center.  The installed files are located at /opt/Adobe/Reader9/
The reader runs ok except when I want to change some preferences, I've found that I can only view Preferences, but I cannot change it.  All options are protected including the Cancel and OK buttons.  I can only close the Preferences window.
Is it just a simple permission (chmod on some files) issue?
Many thanks.
    Nov 8, 2011 9:58 PM   in reply to woop11.04
    If you have the latest updates, then Acrobat Reader 9.4.2 does (at least) partially work in Ubuntu 11.10 + Unity.
    There are a number of minor glitches - due to changes in Ubuntu's undelying GUI, kernal, etc. in the upgrde to Ubuntu 11.10 (Oneiric).
    -  floating scroll bars (only appearing when you hover mouse-cursor)
    DOES NOT WORK: Does not scroll page ..
    You may need to disable this feature.  (in CCSM)
    -  Edit >> Preferences
    This tries to work, but loses focus.  I can see the Cancel and Ok buttons, but they don't do anyhting.
    This is a GTK+ library issue, and an update to 9.4.2+ is needed.
    Summary: There are a number of minor GUI issues that haev existed in 9.4.x for Linux.  The update to Gnome 3 and Unity (for Ubuntu 11.10) has definitely made this much worse.
    Nov 26, 2011 10:19 PM   in reply to woop11.04
    I just found that you can, in fact, make changes to the Preferences using the keyboard. Use <tab> to move between selections, <spacebar> to select or unselect checkbox options, and <arrow> keys in spinners. To finalize, select the OK button using the <tab> key and press <enter>. It appears you have to pres the key a few times, or maybe there is a delay and I was too impatient.
    Hope this helps.
