Claudia_Adobe_DI
Error Code U41M1C212
Sep 2, 2011 10:33 AM
ISSUE
"The update server is not responding. The server might be offline  temporarily, or the internet or firewall settings may be incorrect.  Please try again later. Error Code U41M1C212"
RESOLUTION
  • Disable any inactive Wireless Connection (in as much as possible, be on a hard-wired connection)
  • Disable your Anti-virus
  • Disable your Firewall
  • Noel Carboni
    Dec 23, 2006
    Sep 2, 2011 5:32 PM   in reply to Claudia_Adobe_DI
    Are you saying you solved this issue using the listed resolutions, or that you still have it?
    -Noel
    Sep 5, 2011 1:49 PM   in reply to Noel Carboni
    Whether or not she still has this issue, I certainly do and would love to find a solution.
    So far I have tried the suggested solutions as well as uninstalling, rebooting, then re-downloading, then reinstalling CS5 and I still receive that error.
    Windows 7 64-bit
    Photoshop CS5 64-bit
    How do I resolve that issue?
    CAZ
  • Noel Carboni
    Dec 23, 2006
    Sep 5, 2011 2:34 PM   in reply to Cazlaw11
    Question to those with this problem:  What Internet security / firewall / other software that could affect network access are you running?
    -Noel
    Sep 5, 2011 3:48 PM   in reply to Noel Carboni
    I run Kaspersky only.  I have been certain to shut it down and confirm that Windows doesn't also have a firewall running before loading CS5.
  • Noel Carboni
    Dec 23, 2006
    Sep 5, 2011 3:55 PM   in reply to Cazlaw11
    Yes, but the Adobe updater is a separate and apparently complex beast that (under some conditions at least) starts when you log into Windows.  It might not be happy with the conditions then vs. the time when you run Help - Updates.
    The technical detail about exactly what network access it requires and when the various parts of it need what access are beyond me.  It does seem a fair bit more complicated than it should be, from a pure observer's perspective.
    Oh, and by the way, it works just fine with the Windows 7 firewall on and with the Avast Internet Security software I run on.  I only mention this to assure you that it CAN work.
    -Noel
    Sep 5, 2011 3:56 PM   in reply to Noel Carboni
    Thanks for considering this problem.  I suppose that if there was an easy solution, I would have found it when I Googled the error code.  It seems like the ultimate advice is, "Install the updates manually".  Oh well.
    Thanks again,
    CAZ
  • Noel Carboni
    Dec 23, 2006
    Sep 5, 2011 4:01 PM   in reply to Cazlaw11
    It might be as easy as deinstalling the internet security software you have and switching brands - I honestly don't know.  Folks for whom it's working can usually only give advice on combinations they know do work.
    -Noel
    Oct 29, 2011 2:03 AM   in reply to Claudia_Adobe_DI
    I too have the same problem, getting the error code U41M1C212.
    This is a problem on the desktop only. On the laptop all is running OK.
    Both are Mac's, both running the same programs.
    The only thing that I can think of that is differant between the two, I did have a trial verson on the desktop at one time.
    Whether this has some bearing on the problem I've no idea.
  • Noel Carboni
    Dec 23, 2006
    Oct 29, 2011 9:15 AM   in reply to 1jimjames
    1jimjames wrote:
    Both are Mac's
    You might want to post over in the Macintosh-specific forum - this one is for Windows.  Over there you'll find more expertise on solving Mac system issues.
    http://forums.adobe.com/community/photoshop/photoshop_macintosh
    -Noel
