MarkLav
Cant install Adobe After Effects in Production Prem 5.5
Sep 4, 2011 8:53 AM
Brand New Computer 64bit windows i7chip 49gig avail 12 gigoram
All the other production premium installs great except for AF
please help.
Exit Code: 6
-------------------------------------- Summary --------------------------------------
- 1 fatal error(s), 9 error(s), 12 warning(s)
WARNING: DW031: Payload:{2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 3.0.0.0 has been updated and has been selected for repair. The patch {42774483-D33C-46F7-8B20-FD0B1A3DAC25} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0 will be uninstalled now.
WARNING: DW034: Warning: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
WARNING: DW034: Warning: {4058E728-84D8-45CE-8E2D-5F35BD6659A1} Adobe Extension Manager CS5.5 5.5.0.0 will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
WARNING: DW034: Warning: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw 6.0.0.0 will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
WARNING: DW034: Warning: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) 6.0.0.0 will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
----------- Payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE 1.6.0.0 -----------
----------- Payload: {0094FC04-A548-4D8F-87C1-140431F76C2E} Adobe ExtendScript Toolkit CS5.5 3.6.0.0 -----------
----------- Payload: {2EE4F060-CEE6-4002-AA8B-91B791541767} Pixel Bender Toolkit 2.6.0.0 -----------
WARNING: DF035: CreateAlias:Icon file does not exist at C:\Program Files (x86)\Adobe\Adobe Utilities - CS5.5\Pixel Bender Toolkit 2.6\windows\pb_app.icofile:\\\C:\PIXELB~1\source\winwood\Staging    0X1.5E8EC3P-1021rea\windows\pb_app.ico42178f80493091e8e552c84a2897e9d a68fce32_32_f80493091e8e552c84a2897e9da68fce for icon C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Adobe Production Premium CS5.5\Adobe Pixel Bender Toolkit 2.6.lnk with target C:\Program Files (x86)\Adobe\Adobe Utilities - CS5.5\Pixel Bender Toolkit 2.6\Pixel Bender Toolkit.exe(Seq 89)
----------- Payload: {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 10.0.0.0 -----------
----------- Payload: {7202D4A7-F7E6-4e7a-B77D-7B1C4E8B5CA6} Adobe Flash Player 10 ActiveX 10.0.0.0 -----------
ERROR: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Mark\AppData\Local\Temp\InstallAX.exe, command: -install activex -msi
ERROR: Install MSI payload failed with error: 1603 - Fatal error during installation.
MSI Error message: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Mark\AppData\Local\Temp\InstallAX.exe, command: -install activex -msi
----------- Payload: {43A1C48E-3E50-410e-951C-E17A66BBF824} Adobe Flash Player 10 Plugin 10.0.0.0 -----------
ERROR: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Mark\AppData\Local\Temp\InstallPlugin.exe, command: -install plugin -msi
MSI Error message: Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: C:\Users\Mark\AppData\Local\Temp\InstallPlugin.exe, command: -install plugin -msi
----------- Payload: {E82097B9-A3B8-404A-9A92-AC16A8AC9576} Adobe After Effects CS5.5 10.5.0.0 -----------
FATAL: DS003: Cannot extract 'E:\Mark\Desktop\Adobe CS5.5 Production Premium\Adobe CS5_5\payloads\AdobeAfterEffects10.5AllTrial\Assets1_1.zip' to 'C:\Program Files (x86)\Common Files\Adobe\Installers\adobeTemp\{E82097B9-A3B8-404A-9A92-AC16A8AC957 6}'. Error: Error 0
WARNING: DW036: Payload cannot be installed due to dependent operation failure
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050:  - Adobe Flash Player 10 Plugin: Install failed
ERROR: DW050:  - Adobe Flash Player 10 ActiveX: Install failed
ERROR: DW050:  - Adobe After Effects CS5.5_AdobeAfterEffects10.5en_USLanguagePack: Install failed
ERROR: DW050:  - Adobe After Effects CS5.5: Failed due to Language Pack installation failure
    Sep 4, 2011 6:00 PM   in reply to MarkLav
    Did you have a trial or beta version of AE installed on the computer?
    Sep 4, 2011 11:04 PM   in reply to MarkLav
    Manually uninstall Adobe Flash Player and Adobe AIR, then try this again.
    Mylenium
  • Sharad Saxena
    Apr 30, 2010
    Sep 5, 2011 4:37 AM   in reply to MarkLav
    1) Following error is ignorable based on kb doc -
    "MSI Error message: Error 1722. .... InstallAX.exe, command: -install activex -msi"
    2) Some asset files of the installer have got corrupted causing the error -
    If you have the original media run from the media itself or download a fresh copy of the installer and then run.
    See if it solves your problem.
  • Sharad Saxena
    Apr 30, 2010
    Sep 5, 2011 9:37 PM   in reply to MarkLav
    Good to hear that and thanks for the update.
