• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Cut out a portion of pdf?
Engaged ,
Sep 04, 2011 Sep 04, 2011
Hi. I have Acrobat 8 Professional.
I'm currently scanning in some articles from a newspaper. I scan in the article and use "cut" to get a box around the article of interest. Unfortunately, there is usually a photo which is 4+ columns wide and an article which is 2+ columns wide, so I want an irregular shape for the pdf. If I were physically creating a book, I would use scissors to cut away stray columns, but I cannot find a way to create anything but a box in Acrobat. If I open the PDF in Photoshop, I can "cut" a stray column and remove it, but this does seem needlessly effort-ful.
Could you please tell me how to accomplish this task in Acrobat?
Theresa
Views
108.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Sep 04, 2011 Sep 04, 2011
You can use the Redaction tool to mark areas you want to remove, and when you apply the redactions those areas will be white-out.
Be aware that this is not reversible, so you might want to save copies of your files before starting.
Votes
Translate
Translate
Community Expert ,
Votes
Translate
Translate
Report
Report
Guest
Sep 05, 2011 Sep 05, 2011
by redaction tool do u mean touchup object tools in adobe Prof. or is it something else to edit and remove??
Votes
Translate
Translate
Report
Report
Community Expert ,
No. By Redaction tool I mean the Redaction tool: View - Toolbars -
Redaction.
Votes
Translate
Translate
Report
Report
Engaged ,
Sep 09, 2011 Sep 09, 2011
I've tried the Redaction tool. It paints black across the area which is quite discomforting. Can I change it to white?
Also, I'd like to keep the upper and lower portions of a pdf page. Is there a way I can mark and delete a portion of one page?
Also, once I've trimmed the pages, I have two small ones. Is there any way I can paste these two pages together inside Acrobat?
Thanks (hugely) for your help!
Votes
Translate
Translate
Report
Report
LEGEND ,
Sep 10, 2011 Sep 10, 2011
You can't really delete a portion of a PDF and have the rest close the space. You try using the object touchup tool to select an item and them move it. That is likely the best way to close the page up as you mention. You could then resize the page with the cropping tool, but the latter will not delete anything, only change how it is viewed. Remember to use the Save As when you finish. The save will keep the old stuff too. Bill
Votes
Translate
Translate
Report
Report
Community Expert ,
Sep 11, 2011 Sep 11, 2011
LATEST
Yes. Go to Redaction Properties and change the "Redacted Area Fill Color" setting.
Votes
Translate
Translate
Report
Report
