We have an existing RH9 project and we want to make it accessible to multiple authors. Where can I find a simple step-by-step guide for using RoboSource Control to set up a multi-author environment? We have RH9 Server.
I have looked at the RoboSource Control help file and I find it rough going -- it seems to be targetted at network specialists rather than help authors.
Take a look at the RoboHelp Developer Center.There are several walktrhoughs for integrating RoboHelp with version control systems. If you have problems with a specific source control center you can alsways post back. There's sure to be someone using the same source control as you.
Greet,
Willam
Hi, in addition to Willam's excellent suggestion, I thought I'd elaborate a little since this comes up quite often.
If you are deploying RoboSource Control in a Windows 32-bit environment, I would direct you to this article first:
Getting started with RoboSource Control 3
http://www.adobe.com/devnet-archive/robohelp/articles/robosource.html
This gives a pretty good step by step procedure for setting it up. But you may also want to take a look at alternatives that can be integrated into RoboHelp:
Alternatives:
RoboSource Control was inherited by Adobe from the old eHelp Corporation and has not been modified since. There are some known issues when used on the increasingly popular Windows 7 64 bit machines. Therefore you would be advised to look at alternatives which Adobe has helpfully documented (see below).
It seems most new installations of Source Control for RoboHelp are turning to open source (free) applications like Subversion (with Tortoise SVN)
You can read an Adobe article on this here:
http://www.adobe.com/devnet/robohelp/articles/robohelp_subversion.html
Another alternative is explained by Mark Whisler (a well-known Forum contributor here!) in his article:
Integrating RoboHelp 9 projects with Perforce
http://www.adobe.com/devnet/robohelp/articles/perforce-integration.htm l
RoboHelp can also be used with Team Foundation Server if that is something your company is already using. A good article explaining this can be found here:
http://www.adobe.com/devnet/robohelp/articles/robohelp-tfs-integration .html
For the record, the RoboSource Control 3.1 (32 bit only) is still available and can be found here:
RoboSource Control can be installed from your DVD or unzipped download.
If you have TCS3, it will be found in \Add-ons\Adobe RoboHelp 9\RoboSource Control.
If you have RoboHelp 9, it will be found in \RoboSource Control.
Hope you will find these alternatives helpful.
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Evergreen, Colorado
www.showmethedemo.com
A new Windows 64-bit fix for RoboSource Control was announced today.
http://kb2.adobe.com/cps/917/cpsid_91739.html
If you are running RoboSource Control on 64-bit machines, you might face problems checking in files.
John Daigle
Evergreen, Colorado
North America
Asia Pacific
