[CS5][JS] UserInteractionLevel equivalent for ID Server?
Sep 9, 2011 7:49 AM
Hello,
I need to be able to ignore some warnings that occur in scripts that run on our InDesign server. I've tried using something like:
app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
However, this does not work when the script is executed on the server. There must be a way to set some sort of "interaction level" for scripts that run on the server... since the server gives me a warning that says "...you can click OK or cancel..."
I've seen that someone had the same error, but didn't appear to have a solution:
http://forums.adobe.com/thread/328431 (from 2008).
If anyone has any ideas about this, it would be greatly appreciated!
Many thanks in advance,
-Lloyd
    Sep 9, 2011 1:30 PM   in reply to lhanneman
    Hi Lloyd,
    Where is this error coming from? I mean, where are you seeing this error message? How are you sending your script to InDesign Server?
    InDesign Server doesn't have a UI, so it doesn't have a user interaction level--or anyplace to "click OK or cancel". It's possible that this is a bogus error message, but I'd need to know more to even make a guess.
    Ole
    Sep 9, 2011 2:07 PM   in reply to lhanneman
    Hi Lloyd,
    It seems to me that there are settings for ignoring errors/warnings, but I'm just not familiar enough with Server to know exactly how to get at them. I can see that I'm going to have to install ID Server to be able to troubleshoot this! Give me a few days. In the meantime, we can hope that someone else will chime in with an answer.
    Ole
