Expand my Community achievements bar.
SOLVED
Enterprise Cafe Login issue....
Avatar
Level 1
I am facing a very unknow type of error, will login to Adobe Enterprise Cafe.....
I have my internet connection working fine, able to login to adobe site, with adobe id. But when I start my Enterprise Cafe instance on my machine, it says,
"Currently viewing in off-line mode. some of the plugins and their content will not be available". I check everything related to internet connection. and its working fine.
Note: I am working on Mac OS X 10.6.8, with Adobe AIR 2.7
I believe, others would have also faced the same issue.
Thanks i Advanced.
Ravi.
1 Accepted Solution
Avatar
Correct answer by
Employee
Go ahead and remove the Cache from Cafe located here:
C:\Users\\AppData\Roaming\EnterpriseCafe.E7BED6E5DDA59983786DD72EBFA46B1598278E07.1 <- Delete all files.
Lastly, if this does not work, it may be an AIR issue. Remove Cafe, then AIR, then reinstall Cafe and you should be fine.
Cheers – Marc.
end
View solution in original post
Avatar
Correct answer by
Employee
Cheers – Marc.
end
Avatar
Level 1
Thanks a lot for helping.
Cheers, Ravi.
