Hi All,
One of my client has provided a url which provides me a simple xml file.
I just need to retrieve the xml tag values from the xml and use it in the pdf. I couldn't find a way to do it.
Is it there any way i can retrieve these xml values in my pdf?
Please find the code to retrive xml data using javascript.
xmlhttp=new ActiveXObject("Microsoft.XMLHTTP");
if (window.XMLHttpRequest)
{// code for IE7+, Firefox, Chrome, Opera, Safari
xmlhttp=new XMLHttpRequest();
else
{// code for IE6, IE5
xmlhttp.open("GET","url link
",false);
Message was edited by: Abhishek110486
Views
Total Likes
You will have to save the xml to a local file. Then you can create a new data connection from Designer and bind the fields on the form to the nodes in your xml structure. Once that is done you can open the form in Acrobat/Reader and import the xml file and the bindings that you setup will put the data from the ppropriate node into the bound field.
Make sense?
paul
Views
Total Likes
