Enterprise Version Inventory for Adobe Reader
Sep 15, 2011 9:47 PM
Is there a tool or method to build an inventory of Adobe Reader installed on computers in a domain?
This would allow specific targeting of Adobe Reader updates to the computers who needed it, say from version 9 to version 10.
    Sep 15, 2011 11:38 PM   in reply to Doigy
    In case you have any deployment system like GPO in place, you can use a simple startup script to check for the presence of the following registry key(s):
    i. HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Acrobat Reader\10.0
    ii. HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Acrobat Reader\9.0
    A system with any version of Reader 9 installed would only have Registry (ii) whereas a system with Adobe Reader X would have registry (i) present.
    You can collect the information based on the same.
    Hope this helps.
    Ankit
    Sep 16, 2011 1:06 AM   in reply to Doigy
    Thanks for trying out the suggestion.
    I guess the machines that you have, are 64 nit machines, and so the registry key would be located at:
    i. HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Adobe\Acrobat Reader\10.0
    ii. HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Adobe\Acrobat Reader\9.0
    You can modify the script to look for these keys instead on 64 bit systems while look for the earlier mentioned keys on 32bit systems.
    Ankit
