Is there a way to keep images opened in Photoshop 5 from 'glueing' together?
Sep 16, 2011 2:30 PM
I'm moving from CS3 to CS5 and am innundated with the 'improvments' in CS5. My main problem is that I don't know how to search on something that I don't know the proper name of, for instance, until I was told that the zoom behavior I wanted to disable was called 'scrubby zoom' THEN I was able to locate and uncheck.
This time, the behavior I would like to turn off is the 'magnetic' quality which opens images in a tabbed set, rather than in loose separate cascading images as was the behavior in CS3. I would like to keep images I open separate and not glued together. I would also like to do without the 'magnetic' quality which causes images to want to become 'tabbed sets' if I happen to drag one image window over or close to another as I am trying to compare two images on-screen - I do not want them to merge or want to 'join together' as is the behavior I now am experiencing.
Where are the controls to disable this 'glueing together' behavior of open image windows?
TIA,
Ken
    Sep 16, 2011 2:58 PM   in reply to Saskatchewanobie
    You really should spend some time learning about new features when you install a new version.
    In preferences- > Interface turn off "open images as tabs" and "Enable Floating Document Window Docking".
    Dec 20, 2011 11:39 PM   in reply to Saskatchewanobie
    This book (click here) proved invaluable to me when I moved from CS3 to CS4.  I'm not sure if there's a version for CS5—and I haven't really looked because I'm not interested in Photoshop 12.x as it doesn't run on my machine—but if you found something similar it would solve all your problems.  It takes you through all that's new or different from earlier versions.
    2.5 GHz Power Mac (PPC) G5-Quad; 16GB RAM; mutant, flashed 550MHz nVidia GeForce 7800GTX, 1,700MHz 512MB VRAM; ATTO ExpressPCI UL5D LP SCSI card; Mac OS X Tiger 10.4.11 and Leopard 10.5.8 boot drives; Spotblight, Dashboard and Time Machine permanently disabled; dual 22" CRT monitors; USB wireless 'n' available but connected to the Internet via wired Ethernet; FW flatbed scanner; 2 SCSI scanners (one tabloid-size transparency scanner and a film scanner); various internal & external HDs; FW Epson 2200 and Ethernet Samsung ML-2850ND printers; 2 X Back-UPS RS 1500 XS units.
    ____________
    Wo Tai Lao Le
    我太老了
  • PECourtejoie
    Jan 11, 2006
    Sep 19, 2011 3:16 AM   in reply to Saskatchewanobie
    Hello, I suggest that you take a look at the help files, they are getting better and better as time passes. Indeed, it is difficult to locate functionality if you do not know its name, but the help file is made by sections, so you might find it handy. http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e 41001031ab64-74e0a.html is the "viewing images" part of workspaces, and you may find a link to "display images in different windows" or "zoom in and out" link that you might have found handy.
    If you do not always have internet connectivity, I suggest that you search on your machine for the Adobe Community Help application, and load it with the offline content on regular basis.
    Hope this helps!
  • PECourtejoie
    Jan 11, 2006
    Dec 21, 2011 12:20 AM   in reply to Saskatchewanobie
    Ken, Chris' answer was maybe not directed at you, but rather prompted because there are often many users that ask for help before trying to search even a bit...
    As a designer and daily user of Photoshop, your question about an "old" change, might have seemed to indicate that, given the fact that it had been covered in many reviews and tutorials, already for a few years.
    It is sometimes difficult, when one is living and breathing Photoshop, to remember that some users made the jump lately, and might not follow every training video, blog, or newspaper, because they might not have had the inclination, or just the time to do so.
    Don't judge his sentence as a confrontation, it is rather a matter of each person not seeing the issue from the same perspective.
    Still, when one does not know the chosen terminology, it does indeed makes searches difficult, hence the presence of this very forum.
    Be aware that if you turn off OpenGL, you will lose other functionnality.
