Wookie
Dynamic dropdown using URLs from database (PHP / MySql)
Sep 20, 2011 8:24 AM
I have two list boxes. The 2nd dropdown dynamically displays the content related to the users selection from the 1st dropdown.
This all works as I want it to.
The next step I want to achieve is when an item is selected from the 2nd dropdown and the form is submitted the relevant page opens (I have a column in the database table which stores the URL's)
Any help would be greatly appreciated!
These are my database tables:
table 'Category' for 1st dropdown
cat_id    category                          item_code
1            Moulded Letters                ML
2            Moulded Letters (Extra)     MLE
table 'Subcategory' for 2nd dropdown
cat_id    subcategory       destination_page         item_code
1            1700mm             detail_ml1700.php          ML
1            2000mm             detail_ml2000.php          ML
1            2500mm             detail_ml2500.php          ML
1            2900mm             detail_ml2900.php          ML
2            600mm               detail_mle600.php          MLE
2            900mm               detail_mle900.php          MLE
2            1200mm             detail_mle1200.php        MLE
2            1500mm             detail_mle1500.php        MLE
This is the code for my page, I think I need to tinker with the code in the FORM ACTION section but I can't seem to assign the URL's from the database.
See the section highlighted in bold:    echo "<form method=post name=f1 action= **URL in database** >";
<?php require_once('../Connections/conn_test.php'); ?>
<?php
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
  $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
  $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch ($theType) {
    case "text":
      $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
      break;
    case "long":
    case "int":
      $theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case "double":
      $theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
      break;
    case "date":
      break;
    case "defined":
      $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
      break;
  return $theValue;
mysql_select_db($database_conn_test, $conn_test);
$query_rsSigns = "SELECT * FROM subcategory";
$rsSigns = mysql_query($query_rsSigns, $conn_test) or die(mysql_error());
$row_rsSigns = mysql_fetch_assoc($rsSigns);
$totalRows_rsSigns = mysql_num_rows($rsSigns);
$dbservertype='mysql';
$servername='localhost';
$dbusername='****';
$dbpassword='****';
$dbname='***';
connecttodb($servername,$dbname,$dbusername,$dbpassword);
function connecttodb($servername,$dbname,$dbuser,$dbpassword)
global $link;
$link=mysql_connect ("$servername","$dbuser","$dbpassword");
if(!$link){die("Could not connect to MySQL");}
mysql_select_db("$dbname",$link) or die ("could not open db".mysql_error());
<!doctype html public "-//w3c//dtd html 3.2//en">
<html>
<head>
<title>Multiple drop down list box</title>
<SCRIPT language=JavaScript>
function reload(form)
var val=form.cat.options[form.cat.options.selectedIndex].value;
self.location='dd.php?cat=' + val ;
</script>
</head>
<body>
@$cat=$_GET['cat']; // Use this line or below line if register_global is off
if(strlen($cat) > 0 and !is_numeric($cat)){ // to check if $cat is numeric data or not.
echo "Data Error";
exit;
//@$cat=$HTTP_GET_VARS['cat']; // Use this line or above line if register_global is off
///////// Getting the data from Mysql table for first list box//////////
$quer2=mysql_query("SELECT DISTINCT category,cat_id FROM category order by category");
///////////// End of query for first list box////////////
/////// for second drop down list we will check if category is selected else we will display all the subcategory/////
if(isset($cat) and strlen($cat) > 0){
$quer=mysql_query("SELECT DISTINCT subcategory FROM subcategory where cat_id=$cat order by subcategory");
}else{$quer=mysql_query("SELECT DISTINCT subcategory FROM subcategory order by subcategory"); }
////////// end of query for second subcategory drop down list box ///////////////////////////
//////////        Starting of first drop downlist /////////
echo "<select name='cat' onchange=\"reload(this.form)\"><option value=''>Select one</option>";
while($noticia2 = mysql_fetch_array($quer2)) {
if($noticia2['cat_id']==@$cat){echo "<option selected value='$noticia2[cat_id]'>$noticia2[category]</option>"."<BR>";}
else{echo  "<option value='$noticia2[cat_id]'>$noticia2[category]</option>";}
echo "</select>";
//////////////////  This will end the first drop down list ///////////
//////////        Starting of second drop downlist /////////
echo "<select name='subcat'><option value=''>Select one</option>";
while($noticia = mysql_fetch_array($quer)) {
echo  "<option value='$noticia[subcategory]'>$noticia[subcategory]</option>";
echo "</select>";
//////////////////  This will end the second drop down list ///////////
//// Add your other form fields as needed here/////
echo "<input type=submit value=Submit>";
echo "</form>";
</body>
</html>
<?php
mysql_free_result($rsSigns);
