SubFormA
TableA
DropDownList1
DropDownList2
TextName
DateToday
NumericAlpha
NumericaBeta
ButtonDelete
./TableA
ButtonAdd
/SubformA
Each field (denoted in bold) is mapped to a schema. All non-bold items have bindings of "None" TableA has a default binding of None and is set to repeat for each data item with no min count, no max, and no initial count.
When I click my "ButtonAdd' I create a new instance of TableA via "_TableA.addInstance(true);" and I remove the instances via ButtonDelete: "_TableA.removeInstance(this.parent.index)"
Pretty straight foreward so far.
The problem is this: When I add a second instance of TableA, DropDownList1 copies the value from the first instance. Furthermore, if I pick a new choice in DropDownList1 from either instance, the change is reflected in the other. No other values are mirrored like this. Furthremore, if I add a thrid, fourth, etc instance, these instances work indipendently as expected. Lastly, if I remove the first two instances via ButtonDelete, all remaining instances continue to act normally.
I've no idea why this is happening. Any ideas?
North America
Asia Pacific
