Adobe FMS 4.5 install instructions missing
Sep 24, 2011 6:25 PM
Tags: #help #php #hls #hds #install #apache #fms #4.5 #questions #iis #linux #bundled #gd #phpmysql #broken
Dear Adobe. I attempted to Install FMS 4.5 with all its modules by installing apache seperately from the FMS installer on Linux However the installation notes do not specify how or where to get the information on how to install all the FMS 4.5 functionality such as HLS to Apple/IOS. But this is the part that messes me up if I install YOUR version of apache  then it is supported. Now correct me if I'm wrong because this was the case the last time I tried to install your version of apache. Last time I installed your bundled version of apache and then attempted to install PHP for apache with the modules GD,php_mysql and it didn't work. I attempted to make it work for days. So please tell me how do I install PHP,PHP_GD and PHP_MySql on your bundled version of apache? Also How do I install FMS 4.5 including HLS for Apache on  Linux/Windows that is not bundled or for Microsoft IIS ? Maybe you will answer this maybe you won't in the past I've usually been on my own at this point. Luckily I will post the answer on this forum if I ever figure it out on my own. I doubt you will give me phone/technical support since I use the FMS developer edtion.
        --calmchessplayer
    Sep 25, 2011 11:12 PM   in reply to calmchessplayer
    You can very well use your external Apache..
    All you need to
    1. extract out required modules and dll's from the FMS installation/<Apache>/<modules> folder and place in your external Apache/modules folder.
    2. Pick required configurations from httpd.conf from FMS installation/<Apache>/conf/httpd.conf and place in your external Apache/ conf/httpd.conf file.
        For this look out for following configs..
        1.
    LoadModule f4fhttp_module modules/mod_f4fhttp.so
    LoadModule hlshttp_module modules/mod_hlshttp.so
    LoadModule jithttp_module modules/mod_jithttp.so
    And configs under location tag hls-live, hds-live hls-vod, hds-vod
    Sep 26, 2011 12:00 AM   in reply to Nitin Goel
    Also would like to add some infromation to what Nitin had said. I just wanted to let you know that Apache version which comes with FMS installation in 2.2.17 and  .dll/.so of relevant modules are best suited to work for that Apache version - needless to say all testing was done on same Apache version. So it would be best advised that your external Apache matches 2.2.17
    Sep 26, 2011 9:55 PM   in reply to calmchessplayer
    I agree installing FMS 4.5 just to get Apache modules is not best way of doing it - let me figure out if i can put across this to product managment and have some kind of zip or tar file for download and with proper instructions. Would that do you for you -  or you think there is better way of doing same thing.
    Have you tried external Apache with 2.2.17 - i suppose whatever native Apache you migth have (if its not higher version) - you can always upgrade 2.2.17. I would suggest first you try it out - external Apache with 2.2.17 is tested and it works properly.
    I do not know about PHP because i have not done such testing - but if its not working - i would see it as Apache problem and i think there should be way to work around it. If you think your external set up works with PHP - have you tried setting your external apache with our modules and see if HDS/HLS works fine. I remember you mentioning PHP problem is there only on Windows 7 - so have you tried other platforms of Windows 2008 or CentOS 5.5.
    Sep 26, 2011 10:13 PM   in reply to SE_0208
    "....then uninstall FMS 4.5..."
    Though I am not sure how you want to use the live streaming on HTTP feature without installing FMS. Do you want to use Vod Streaming? If yes, I am sure you won't be happy with only 30 minutes of play in case of developer license.
