Image which sits above a pan object
Sep 26, 2011 5:21 AM
Hi all
Is there any way to get an image to sit on top of a pannable image. I am showing an image within a frame, which you can pull up and down to see more of that image. I'd like to have a button sit on top of that pan image, but it just over writes it. The button is above everything esle...
M
  • Bob Bringhurst
    May 29, 2007
    Sep 26, 2011 10:48 AM   in reply to jmartynhopkins
    Just place the image on top of the image pan. When your customer tap the image pan, the image goes to the background. When they double-tap the image pan, the image comes back to the front. There is an example of this "poster" effect for image pans in the DPS Tips app. See "Pan & Zoom" in the Overlays folio.
  • Bob Bringhurst
    May 29, 2007
    Sep 26, 2011 12:29 PM   in reply to jmartynhopkins
    I understand now. It may be possible to achieve that effect, but it depends on your design. In most cases, you should avoid using transparent images for Pan & Zoom due to the ghosting effect that occurs in which the poster (initial view) remains in the background while the transparent image pans over it. Experiment with a transparent image that you set to Pan & Zoom to see if it works with your design.
