jfharper
MP4 Buffering Problem
Sep 26, 2011 4:47 PM
I've run my mp4 through mp4box which is supposed to put the moov atom at the beginning of the file, and so when I test in the webpage, after pressing play, the video will start downloading and start to play, then playback is paused at 1 second until the rest of the video completely downloads...then playback resumes.  I can't figure out if this is a player problem, server problem, or mp4 problem...if the mp4 starts to buffer then stops, I'm thinking it is not the mp4 or the server since it started to buffer, but does not buffer properly...can someone offer any advice?  Thanks.  BTW, I'm using strobe media playback as the player.
    Sep 27, 2011 1:59 AM   in reply to jfharper
    I could be either:
    - an asset problem (moov atom not correctly moved)
    - an asset length problem. If it's a short asset, the dynamic buffer change from the starting shorter value to the longer playback value (10s) will start rendering the movie when the whole movie has been downloaded
    - a buffering problem (our optimizations applied to your specific video could have affected this)
    Can you try it with optimizeBuffering=false?
    Sep 28, 2011 1:22 AM   in reply to jfharper
    Good job!
    btw, the setup.html page helps you adding the parameters with correct names if you want to do some quick and dirty tests.
    S.
