Show image quality as like original image after resize in as3.
Sep 27, 2011 2:38 AM
Hi Guys,
I am working on a Action Script3 project and i am showing images after resizing. I am using Bitmap and BitmapData manipulation for this but not getting image quality as like original image.  Please guide and help me with code that how can i do this.
Thanks & regards
Rangrajan
    Sep 27, 2011 8:05 AM   in reply to Santosh Rangrajan
    How are you resizing? Normally, you would draw the original bitmap data into the new bitmap data, using a matrix to resize. To smooth scale, you need to use the smoothing option of the draw method. Here's a little sample that takes a library image and scales it to 500x500, using smoothing:
    var orig:BitmapData = new baseMap(); //library image
    var res:BitmapData = new BitmapData(500,500);
    var m:Matrix = new Matrix();
    m.scale(res.width / orig.width, res.height / orig.height);
    res.draw(orig, m, null, null, null, true);
    var c:Bitmap = new Bitmap(res);
    addChild(c);
    toggle the true to false in the draw, to see the difference...
    Sep 28, 2011 3:25 AM   in reply to Santosh Rangrajan
    Let's see an example of your problem then. You're not going to get Photoshop quality scaling - in Flash this is scaling with the vector renderer, it's made for speed vs quality. But with smoothing on I find the scaling to be quite acceptable.
